Question about RCA R52WH73 Projection Television
Double picture, red,blue,green lines
We have taken the back panel off and we are now trying to locate the fuse fl231. We have a RCA R52WH74. possible blown fuse. we just need to know what area of board to find ***.
    Genius:
  • 1,030 Answers
Consult the Article in the tips and tricks section "the fl231 problem"....it give complete instructions on this simple repair and where to locate the fuse
Posted on May 10, 2009
  • swmork Oct 09, 2010
    You keep referring ot an article in the "tips and tricks section". Where is a link to that section? There seems to be no way to search for your article!
  • Willie Howell Oct 09, 2010
    http://www.fixya.com/support/r1062030-fl...
R52wh74 already changed 231 fuse still not converging
Did you change DL231 and CL230 with the fl231? Also did you reflow the solder on the flyback and vertical IC? Bad solder is what blows the FL231, but without changin DL231 and CL230 and resoldering the flyback and vertical the fix wont be fully effective.
Jun 12, 2009 | RCA R52WH73 Projection Television
I have a RCA R52WH74 52'' Projection and the color on the set is in red,green,and yellow. Tried adjusting, however, does not help. Any clue?
sounds like a convergence issue. IS the picture also pulled in from top and bottom. In customer setup menu do you have the convergence option. I suggest you read "the fl231 fuse problem" in the tips and tricks section of this website
Jun 05, 2009 | RCA Televison & Video
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Rca r52wh74 . Double picture .
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Feb 13, 2009 | RCA R52WH73 Projection Television
The Red,Blue,Green do not line up and keeps blowing fuse
you need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | RCA Scenium D40W20 40" Rear Projection...
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
Jan 17, 2009 | RCA HD52W59 HDTV Projection Television
Destorted picture on my tv
the fl231 problem requires a soldering iron. to remove it from the circit board. I would not recomend this for someone who has never soldered before. and consult the fl231 problem under the tips and tricks section
Dec 26, 2008 | RCA HD52W59 HDTV Projection Television
Images doubled and red blue green colors all seperate
Look in menu go to setup see if you have convergence listed on menu if not you have open fuse FL231, located next to flyback on right side there is 3 in aroll small brown looking caps middle one is it FL231.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH73 Projection Television Logo
359 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
