Question about Singer 7442 Mechanical Sewing Machine
Singer 7442 How to get inside ?
Does anyone know how to open the case of a Singer 7442 sewing machine? I removed all the visible screws, yet there are probably still some hidden catches that need to be pressed down in order to open. Thanks for your help.
  • 1 more comment
  • daniel_van_w May 13, 2009
    Thanks. The problem was solved by a repairman. I needed more like a repair guide. Thanks anyway, kind of you.
    Daniel
  • Robin Work Jan 28, 2013
    I am having the same problem getting into the case. My bobbin winder quit working and I want to see if it is something simple to fix.
  • Anonymous Mar 26, 2014
    I can hear a buzz coming from the motor of my singer 4423 sewing machine but, the motor does not work. I took it out from the machine but I don't know how to open it or how to fix it. I will need your help please :). thank you for your time.
  • 3 Answers
How to separate cover on singer 7442
It's likely that you can get the cover above the needle shaft off -- they're often separate. If so, there will be a white disk in the side and one in the back that can be popped of using a screwdriver blade on one side. They each cover a screw that you then remove, and you can see the tension assembly and thread path. Often, there are threads wrapped around one of those things inside. If not, you can remove the hand wheel. If it has a similar white disk in the center, you can pop that off and remove the screw underneath. If there is no screw, then it's a force fit. Squeeze the wheel with your hand while rocking it until it comes off.
If you need to remove the covers, remove the back one first.
Feb 07, 2015 | Singer 7442 Electric Sewing Machine
I have a Singer 4562 T sewing machine. When I try to sew the bobbin case is jumping out of the housing. With the slide closed I sew until everything gets a mess on the underside. When opening the housing...
pl open the entire bobbin housing two scrwes with suitable screw driver and clean .test the latch on the bobbin case,look for steel tension strip screw replace the unit ,also replace needle
Dec 11, 2013 | Singer 7442 Mechanical Sewing Machine
How do I replace the bobbin case in singer machine 7442. The manual diagram is minimal and I replace it incorrectly and just got it out after several attempts. Can't seem to get it aligned proper;u
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Jun 07, 2010 | Singer 7442 Mechanical Sewing Machine
Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
http://homeappliance.manualsonline.com/manuals/mfg/singer/7442.html
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the manual...you don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
May 14, 2010 | Singer 7442 Mechanical Sewing Machine
Oil a 7442 sewing machine
Hi. Your manual will tell you where to oil your machine, or if it's self-oiling (in which case you don't oil it). If you've lost your manual, check with http://www.mastersewusa.com/menu-singer_iinstructional.htm; they have your manual. I wrote a small tip on oiling your machine, too.
Be sure to use good sewing machine oil in your machine. You can get it at any fabric store or order it online. One of my favorite online stores for sewing supplies is Nancy's Notions (http://www.nancysnotions.com/).
Whether or not your machine is self-oiling, be sure to keep the lint cleaned out of the bobbin area. You can use a small brush (even a little paint brush works nicely) and just brush all the bits of lint out. A good habit to get into is to brush all the lint out when you go to put your machine away after each use.
Since you're new to sewing, here's a couple more things that are good to know:
Use good quality thread. Protect your thread supplies from dust and sunlight. Old or cheap thread breaks easily and gives off more lint.
Use a new needle with each project you sew and make sure you use the right size needle and thread for what you're sewing. I wrote a quick guide about which needle to use with what fabric.
Most problems you experience with your machine can be solved by rethreading your machine or changing the needle.
Happy Sewing!
Robbie
Apr 15, 2010 | Singer 7442 Mechanical Sewing Machine
Can't put back the bobbin case in a singer 7442, it get sotck
Put the bobbin into the case so the thread is feeding clock wise and through the guide on the case.
Lift the lever to hold the bobbin in place.
Insert the bobbin case into the race/shuttle, still holding the lever out.
Align the finger on the bobbin case with the opening in the race/shuttle.
You may have to turn the bobbin case a bit to the left or right for it to line up.
Once it clicks into place it should work without any further problems.
Feb 19, 2010 | Singer 7442 Mechanical Sewing Machine
How to do all the stitches on my Singer fm-22-c
i'm uncertain if you have the manual so here it is
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/7442-_M
http://www.scribd.com/doc/3713782/Singer-7442-Sewing-Machine-Manual
it isn't simple to download the manuals but you shouldn't have too much trouble getting them either... be that as it may if you cannot download them from at least one of the pages i sent let me know
Robert
Please take a moment to rate this solution thanks
May 24, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Bobbin Will not wind
I accidentally used 220V for my singer 7442, I don't know if there is a fuse that I can change? can someone help me with this?
Jan 19, 2008 | Singer 7442 Mechanical Sewing Machine
Singer industrial sewing machine
It might be the way you're asking that's confusing the problem. It's simple to remove the hand wheel, slip the belt over the track, and then replace the hand wheel. It really depends on the model of your machine - is it by chance a 328K?
Martie Johnson (USA)
Nov 25, 2007 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
524 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
