PROBLEM IS POSTED. INVOLVES APPLE MINIMAC PC
CAN'T GET PAST THE SPINNING "BEACH BALL" TO THE STARTER PAGE. TRIED EVERYTHING I CAN THINK OF BUT NO LUCK, SO THAT MEANS IT'S PROBABLY A SIMPLY THING AND, THEREFORE, TOO MUCH FOR MY VERY MEAGER KNOWLEDGE OF APPLE PCs.
    Problem Solver:
  • 11 Answers
Go to ur bios and select load fail-safe defualts..save and exit...if that dont work try running in safe mode
Posted on May 27, 2009
Is the bowel from the Hamilton beach slow cooker model33133hw oven safe
Hello, Huston -
Clarification: You are asking about the stoneware bowl (not bowel) for the Hamilton Beach slow cooker, model 33133hw.
If so . . .
Page 3 of the manual for that model of slow cooker states:
(Quote)
The Stoneware is microwave save and oven proof, but never heat the Stoneware when empty.
(End quote)
In case you do not have the owner's manual for the slow cooker, this is the link to web page from which you can download and save it:
https://all-guides.com/manual/390463/hamilton-beach-33133-operation-user-s-manual-44.html?page=1
Best wishes.
Mar 25, 2018 | Hamilton Beach Crock Pots & Slow Cookers
What does flashing globe on white screen on mac meanmacbook pro
If by flashing globe you mean spinning globe (often a colored beach ball), there are several possible reasons. The spinning beach ball happens when a operating system command cannot be completed. The computer is frozen/stuck in a process that it can't complete.
Most often the cause is faulty or missing information on the hard drive. Running Disk Utility will often fix it. You may need to start the computer from your OS install disk and rather than install find Disk Utility in the pull down menu and run it on your hard drive.
The spinning ball could also be caused by insufficient RAM memory to even run the operating system. It could also be caused by hardware problems which can be diagnosed with the Apple Hardware Test found on the disks sold with the machine.
If you truly mean a flashing round globe, I have never seen such a figure. Flashing question marks or flashing circle with a slash through it means the mac cannot find a bootable hard drive. Your hard drive may have died or become corrupted. To see if you hard drive is defective, again run Disk Utility by booting off an install CD or another hard drive with a compatible MacOSX operating system to diagnose.
Try running the repair disk program under the general tab of the Disk Utility program.
Aug 11, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My MacBook Pro shows the message "Not Charging"
It could be either. Your best bet is to just take it to Apple and let them run a battery/adapter tester. That'll verify everything. Otherwise you can use a different battery and see if the same thing happens.
Jun 16, 2011 | Apple MacBook Pro Notebook
Im getting a folder with a question mark
boot from an install or system CD, after selecting english the next page has a menu along the top, select utilities and then disk utility, if the HD is ok it will show up when the daisy or beach ball stops spinning, if it does not you will need a utility like disk warrior, if there then select repair disk, when this has run select repair permisssions, this is slow. when done go back to utilities (you may have to quit disk utility and open the utility folder again and select start up disk, your HD should show up, select it and restart. if this fails you have to try am archive and install.
Jan 11, 2011 | Apple iBook G4 Mac Notebook
Nothing from my desktop shows up when I turned my lap top on. When I last shut down - I don't think I shut it down right. Got the spinning beach ball. Nothing is working now
Check for a failing hard drive
Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
If you don't get errors you then need to reinstall your operating system.
Dec 26, 2010 | Apple MacBook Mac Notebook
Spinning wheel of death (beach ball)
Open the Activity Monitor application can see what process is taking the most CPU time.
You can also use the "top" utility by opening the Terminal program and then typing "top" and pressing return at the command prompt. To quit top just press the "q" key.
Mar 05, 2017 | Apple Computers & Internet
While is was searching on the internet my iBook G4 locked up. I tried to reboot and it locked up again. I tried to reinstall OSX but during the install it locked up. I replaced the memory and hard drive...
Dude, if you have all the current updates for your OS and applications, then you got a logic board issue. Especially if you you keep seeing the spinning beach ball of death or the dreaded white screen of death.
The iBook G4 is the poster child for logic board defects, because it has to do with the way the circuit boards were flowed.  Apple won't fix this for the iBook G4.  You got to do a big class action lawsuit like they did with the iBook G3 before they will replace the logic board.
Best bet is to sell this thing on e-bay as a non-working unit and get you a better laptop.
Oct 18, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Hard drive failure
www.drivesavers.com
www.ontrack.com
You can contact this companies regarding data recovery. The "Genius" was wrong about the drive being retuned to Apple, that will only occur if you have a system under warranty, and you would be returning it to Apple to avoid being charged.
As far as replacement hard drive going for $325, that too is pretty steep, see this link:
http://search.ebay.com/search/search.dll?from=R40&_trksid=p3907.m37.l1313&satitle=MacBook+Pro+hard+drive&category0=
Apr 06, 2009 | Apple MacBook Pro PC Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
