Question about Maytag MAV3905EWW 13 Cycle Washer
Wobbles when spinning - Maytag MAV3905EWW 13 Cycle Washer
    New Friend:
  • 160 Answers
Check the adjustable feet
Posted on May 10, 2009
  • 1,305 Answers
The load of clothing/towels is out of balance.. you can readjust by hand. Also check the washer feet. they are on screws and you can adjust them with a wrench to relevel the machine and for all four legs to be in contact with the floor... that should help alot...
KEN
Steering wheel wobbles and tires seem to wobble as well
Jack it up at each wheel, spin the wheel, watch it to see if it is out of round, if there might be a bubble in the tire anywhere, (cords break inside the tire), or if the rim is bent. Use chalk as it spins to locate slight flaws. Compare wheel to tire while spinning. Check to see if the wheel is loose either at the hub, axle or lug nuts. Make sure your A frame or tie rods are not coming loose. Use pry bars to see if everything is tight. If your wobble is only when braking it is probably a un-evenly worn brake rotor. Always chock (block) your wheels and apply emergency brake while jacking up a car. Take your time and be safe. Do not get distracted if you are running a jacked up car. Apply brake before moving shifter back to park to stop spinning wheel.
Feb 12, 2014 | Cars & Trucks
My machine is extremely loud when it spins. what do I need to do
I would guess you need to level it. Most washers and dryers have some sort of self leveling in their feet but some do not. Attempt to lift the rear of the machine up two to four inches and then set it back down. Check to see if it wobbles. If is still wobbles you may need to adjust the foot using an open ended wrench.
Oct 18, 2012 | Amana Tandem 7300 Washer and Dryer Stack...
Loud rattling sound top of engine near or below the alternator when idling, goes away if accelerator is pressed
Hello: Remove the serpentine belt, see if the waterpump pulley wobbles/makes noise when you spin it. If thats not it then start the engine, belt still off see if noise is there also while engine is running see if vthe crankshaft pulley wobbles. Also check the A/C compressor pulley (engine off, belt off) spin it by hand and check for noise and wobble. If all the previous is ok then it could be the balance shaft front bearing and or the timing chain.
Oct 18, 2011 | 1998 Buick LeSabre
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
My 1993 Camry steering wheel wobbles when I drive. Gets better as I go faster.
sounds like deformed tyres to me ,jack it up and spin the wheels then check them
Nov 05, 2010 | 1993 Toyota Camry V6
Kenmore Series 80 wobbles when spinning
the basket is attached to a triangular brace that must match up with the frame it sits on.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Maytag MAV3905EWW 13 Cycle Washer Logo
134 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
