Question about RCA 27V520T 27" TV
Power turns on and off by its self
When turned off tv powers it self on and off by its self. front key pad works sometimes most of the time channel up makes the channel go down. lower channels has some white dots flickering. sometimes the tv will last 40 minutes sometimes it will act up in 5 minutes when the power off and on by its self 10 sec. in between until unpluged. I resoldierd the grounds and stil same problems. RCA . Model# 27v414tyx5 chassis# atc010a year# 2006 march
  • Anonymous Jan 13, 2008
    Our RCA Television, Model # 27V250T has all of a sudden decided to have a mind of it's own. Just recently it started to go on and off by itself!! Once in a while it will stay on steadily, but then out of nowhere it will shut itself off and then on again! What could be the problem??
The problem is the key board controller is malfunctioning. I have contacted a multitude of supply houses even
RCA included and I have not been able to buy the part. However, you can bypass the problem by disabling the key board functions by activating the parental control item, not the password, by using the remote. All the keys on the front panel will be disabled but you can still operate the tv with the remote plus save yourself a cost on parts and labor.
Posted on Apr 13, 2008
Boat anchor
On mx900 genesis universal remote the up down arrows to change channels will not work - cannot get guide to display -cannot change channels using#key pad - volume up down work fine suggestions?
Incorrect code. Try different programming codes for one that operates your TV correctly. Note not all universal remotes will work all features of a tv. Sometimes all you can get (especially on lower end remotes) is power and volume
Nov 01, 2016 | Televison & Video
Remote will not turn the TV on
Hi Terry,
It is a common problem with remote controls. The power key is used very much and the conductive rubber pad underneath wears out. If you can, open the hand set and clean the under side of the keys with cotton and solvent (after shave solution will do). It will bring back the action. At least for some time. If it does not work, go for new remote control.
Jan 18, 2014 | Panasonic Televison & Video
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a AL2671w LCD Acer TV ON OFF switching
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
Dec 05, 2009 | Acer Televison & Video
The tv turns channel by it self
hello are you sure 1 of the channel button is not jammed in
shaun
Apr 08, 2009 | RCA R52WH73 Projection Television
After my 70" tv is on for a period of time, it turns off and won't come back on for a while.
Good Day, Connie ss;
The next time the TV turns off try this:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. I hope this was helpful, good luck, big IRISH.
Jul 02, 2008 | Mitsubishi VS-70707 70" Rear Projection...
My tv
My tv will not turn on. We had been away for a week and no power interuption at home. We have unpluged the tv for short and long periods of time . We we attempt to turn the power on it cuts off by itself.
Mar 01, 2008 | Televison & Video
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Scrolling Channels
You probably have a bad channel down switch on the TV. This is common if any kind of liquid spilled inside of the TV near the controls. The other possibility is just a stuck button on the control pad itself. Sometimes the plastic warps a bit causing to rub against the cabinet causing it to stick. Try moving the button and see if it has free movement.
Mar 13, 2007 | RCA F32632SB 32" TV
Televison & Video Logo
182 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
