Question about Cyberhome CH-DVD 300 DVD Player
Player is not reading disc
When you insert disc, it says 'loading' for about minute then reads 'No Disc'
    Scholar:
  • 85 Answers
Are the disks copys? are they badly scratched? if not you could try unplugging the player. take it apart and locate the lasor lens usually under a plastic plate held by two small screws? get a cotton bud and dip one end into isopropyl alchohol or meths and clean the lasor lens rubbing lightly in a circular motion then with the dry end of the bud wipe lightly the lens dry, put the set together and try a disk, if the above does not work a new lasor is needed,
Posted on May 10, 2009
5 Suggested Answers
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
vortash
  • 431 Answers
SOURCE: It won't read disc. After loading, it reads No Disc
Sounds like a read error fault , possibly a laser malfunction sometimes dirt on the lens will cause this try a good CD cleaner if this is no good I suggest a free engineers estimate at least you can then ask again on here how to fix it . My honnest guess is either a duff laser or software corruption . I have known seating of the tray to cause this also not returning fully back into machine , usually caused by children and alien matter ? shall we say such as choclate or M&MS kids shove stuff everywhere ? bless them lol
hope this helps Regards Vortash
Posted on May 12, 2009
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
jdvillanueva
  • 2098 Answers
SOURCE: when i insert a disc in my dvd player it reads "no
Hi mgarragh1,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I would advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 23, 2011
DVD player will not recognize any disc
That cd play will not read the format on the ****,you need to try a diff type of disc
Sep 04, 2012 | Panasonic Televison & Video
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
When I insert myDVD disc, the screen shows loading for a minute or so--then reads incorrect disc and bad on the player. This is a disc I have used before and has the label that shows it is the disc this...
It seems that optical laser block gets fail to read data on disc and possible cause could be dirty/ clogged lens or optical laser block failure.
Put lens cleaning disc in unit to clean optical lens and check DVD playback, if that does not solve the issue then optical laser block would be defective and requires replacement that would cost approx new player price.
Hope these info will help.
Thanks.
Jun 29, 2011 | Toshiba SD-K220S DVD/CD Player w/Built-in...
My lg bd50 is able to play any normal dvds however it is unable to play any bluyray dvds!!! when a blueray is loaded into the machine you cannot even eject the disc for sometime. i downloaded updates to...
hi,
blue ray players takes one to two minute to read the content. it will not read as fater as dvd. give some time and then find out what the player says. error or no disc. also check ur BD's region and the region of the disc u inserted. BD's comes with only one region.
ok
Dec 17, 2010 | LG BD350 Blu-Ray Player
HOW DO I TYPE NAMES OF CD OR DVD ?
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
The manual for this unit is available at: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPCX850D .
I hope this helps.
Oct 12, 2010 | Sony DVP-CX850D DVD Player
Can't Read Disc
Jul 06, 2010 | Philips DVP5990 DVD Player
When I insert a dvd it says no disc
DVD need replesment of optical lens,then its ok
Jul 09, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Oct 06, 2007 | Jwin JD-VD149 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
172 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
