Question about Hampton Bay 46056 Callaway II Ceiling Fan
Can't connect light assemble, because the wire connector is too big. The space between the light assembling and the fan base does not have the space for the wire connectors. What should I do with the wires to be able to connect the light assembling to the fan base.
    Problem Solver:
  • 9 Answers
Turn the breaker off pull the wires down a little bit it should come down or go to homedepot buy the same guage wire buy 2 wirenuts!
Posted on May 23, 2009
How do i remove rear turn signals on 2009 street bob?
If you need to remove the tail lite, brake lite and signal light harness start by removing the seat. Then disconnect the negative battery cable. Then detach the rear electrical harness connector. Then locate and follow the wires for the taillight and signal lights to the connector (8 pin) under the seat area and separate the connector. Then cut the cable tie strap holding the wiring harness to the frame and pull the harness through the fender opening. Then follow the conduit/harness back to the fender hole where the wiring exits the fender underside and enters the tail lite housing and backplate. This is not necessary for removal of the tail/brake lite assembly or the signal lie assemblies.
If you want to remove the tail/brake lite assembly remove the tail light lens and the with a small screwdriver depress the small tang in the tail lite four wire Multilock connector and remove the tail lite and then do the same and release the two wire signal light connectors one at a time from the tail lite base and remove the signal light connectors. These smaller two wire Multilock connectors are on the left and right sides of the base plate in the centre portions of the base plate where the 4 wire tail lite connector on the left side of the base plate is located and the wiring harness connector of the wires from the front of the bike to the base plate on the right side. The wires from the left and right signal lite assemblies go from these connection points on the base plate out through each side of the base plate and into the area under the back of the rear fender to each signal lite assembly. Then similarly release the Multilock connector of the harness from under the seat to the tail lite base. When you have disconnected the connectors from the base plate and have routed the wire harnesses out into the area under the fender you can release them from the wire clips at each side of the under fender areas. Then for each side remove the lamp support by unscrewing and removing the fastener and washer inside the rear fender, after which the lamp housing can be removed from the lamp support by pulling it and the wiring you disconnected from the tail lite base out through the lamp support. If you wish to release/remove the tail lite base undo the fastener and remove it.
Jun 03, 2014 | 2006 Harley Davidson FXDBI Street Bob
I purchased a reoplacemetn motor for my Nutone/Broan LS 100SE bath fan based on a reccommendation here. The new motor, part # 89169, came with five wires compared to the original motor's three. How do I...
The additional wires are for a starting capacitor, not included with the motor. The easiest way to hook-up is to order the Outlet Assembly p/n 88617000 (available at Coastal Tech Supply.) The assembly includes the capacitor, connector, and shroud; and will replace the existing outlet assembly in the housing. Minor electrical work is required to remove the old assembly and install the new one.
Mar 03, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Having trouble fixing brake lights
Tail/Turn Signal Lamp Removal & Installation Cab/Chassis gm-06-00-1071.gif
To Remove:
  1. Disconnect lamp assembly electrical connector.
  2. Remove nuts and lamp assembly from bracket.
  3. Remove lens screws.
  4. Remove lens, gasket and bulb.
To Install:
  1. Install lamp assembly and nuts to bracket.
  2. Connect electrical connector.
  3. Install bulb, gasket and lens.
  4. Install lens screws.
Except Cab/Chassis gm-06-00-1075.gif
To Remove:
  1. Lower endgate.
  2. Remove 2 tail/turn signal lamp assembly retaining screws.
  3. Rotate tail/turn signal lamp assembly and remove from vehicle.
  4. Disconnect lamp assembly electrical connector.
  5. Remove bulbs by pulling straight out of bases.
To Install:
  1. Install bulbs by pushing straight into bases.
  3. Install tail/turn signal lamp assembly to vehicle and secure with 2 screws.
Oct 13, 2010 | 1997 GMC Sierra
4 month old Hunter 52". After install, when you turned on the tulip lights that came with it, they would come on bright, then dim about 20%. Recently, when the light was turned on, they would blink...
Your problem is you are using too much wattage for your fan. You can solve this one of two ways. Put in lower wattage light bulbs (per your manufacturer recommendations) The other is to remove the wattage governor. There should be 3 screws holding your light assembly on. Remove these screws then disconnect the white rectangular plug in connector (this is what connects the fan wiring to the light assembly wiring). At this point you should be free to take the light assembly to a table. Follow the light pull chain wires from inside. One of these wires will lead to a black box that has 1 black wire, 1 red wire and 2 white wires. Remove this black box...this is the wattage governor. Remove by cutting the 2 white wires as close to the box as you can, peel back the insulation and use a wire nut to connect the 2 white wires together. Remove the wire nut on the black wire from the switch to this black box. Now you have one red wire left and your bare black wire from the switch. You will remove the red wire and put the bare black wire from the switch in it's place. Throw the wattage regulator in the trash and install you light assembly back to the fan. It will no longer blink but you should still use the recommended wattage light bulbs to prevent overheating.
Aug 19, 2010 | Hunter (25417) Ceiling Fan
How do I replace a burned out backup light on a 1998 cheverolet silverado c-1500 pickup truck?
To Remove:
To Install:
To Remove:
  1. Lower endgate.
To Install:
Jul 17, 2010 | 1998 Chevrolet C1500
NEED TO KNW HOW TO REPLACE NO 2 FAN ON A SAMSUNG DLP TV HL-S50786W
Here is Fan part# BP31-00024A. Search google, find it at various places.
Light engine assembly has to be removed. This involves unplugging various connectors between processing/control chassis on the left side and engine assembly on the right side. Mounting screws on the top and bottom of engine assembly. Then remove light engine assembly completely from the TV. Fan#2 is the lamp cooling fan and is located beside the lamp assembly.
It is not too complicated if you draw a picture of where all the plugs are removed from. If one plug is not put back correctly, unit will not work. Usually a tight fight sliding out the engine. Plastic cable tie-down between the 2 assemblies can be cut and discarded, this makes re-installing light engine considerably easier.
Cheat the cabinet safety switch with tape or stretch connecting wire across it to hold it in "on" position for test after reassembly.
Service cost may be $150-$200 if you don't do it yourself. We do it in most Canada cities.
easyab
Apr 22, 2010 | Samsung HL-S5087W DLP TV
How do I replace the headlight bulb on a 2000 Ford Escort ZX2?
² Coupe
² Sedan/wagon
2. Open the hood and disconnect the headlamp wiring socket from the
in-line connector. This will make it easier to change the bulb.
3. Remove the protective dust shield
from the housing by turning the
dust shield counterclockwise (when
viewed from the rear).
4. Release clip and disconnect the electrical connector from the bulb.
5. Remove the bulb retaining ring by
rotating it counterclockwise.
6. Without turning, remove the old
bulb from the lamp assembly by
pulling it straight back out of the
lamp assembly and replace.
7. Install the new bulb in lamp assembly by pushing straight in with the
bulb’s plastic base facing upward. Turn the bulb slightly to align the
grooves in the plastic base with the tabs in the lamp assembly.
8. Install the bulb retaining ring over the plastic base and lock the ring
by rotating it clockwise until it snaps into place.
9. Connect the electrical connector into the plastic base until it “snaps”.
10. Install the protective dust shield and lock the shield by rotating it
clockwise until it locks into position.
11. Connect the headlamp wiring socket to the in-line connector.
12. Turn the headlamps on and make sure they work properly. If the
headlamp was correctly aligned before you changed the bulb, you should
not need to align it again.
__________
Feb 03, 2010 | 2000 Ford Escort
Replacing headlight
Composite Headlights
Most of the vehicles covered by this manual are equipped with composite headlight assemblies. Due to space constraints, no access may be provided to withdraw the bulbs, so the replacement usually requires removal of the composite assembly.
CAUTION The composite headlight assemblies use Halogen bulbs which contain a gas under pressure. Improper handling of the bulb could cause it to shatter into flying glass fragments. To help avoid personal injury, follow the precautions closely.
Exploded view of the composite headlight mounting—1995-97 model shown
Whenever handling a Halogen bulb, ALWAYS follow these precautions:
  • Turn the headlight switch OFF and allow the bulb to cool before changing it. Leave the switch OFF until the change is complete.
  • ALWAYS wear eye protection when changing a halogen bulb.
  • Handle the bulb only by its base. Avoid touching the glass.
  • DO NOT drop or scratch the bulb.
  • Keep dirt and moisture off the bulb.
  • Place the used bulb in the new bulb's carton and dispose of it properly.
  1. Raise the hood and locate the bulb mounting location at the rear of the composite headlamp body.
  2. Disconnect the negative battery cable.
  3. If necessary for access, remove the splash shield or side marker lamp(s).
  4. On some models it may be necessary to remove the side marker lamp.
Unfasten the thumb screws, then ...
  1. If there is enough room to access the plastic base, press in and turn the base 1/4 turn counterclockwise and remove from the metal retaining ring by gently pulling back and away from the headlight. Remove the electrical connector from the bulb by raising the lock tab and pulling the connector down and away from the bulb's plastic base.
  2. If you can't access the bulb from the engine compartment, unfasten the thumb screws, and/or other retainers, then pull the composite headlight assembly forward slightly and disengage the wiring connector. Press in and turn the base 1/4 turn counterclockwise and remove the bulb from the metal retaining ring by gently pulling back and away from the headlight.
... pull the headlight assembly away from the vehicle for access to the bulb and connector
8b6245d.gif \
Remove the retaining ring from the base of the bulb, then ...
... turn the bulb and remove it from the headlight assembly
To install:
  1. Attach the electrical connector on the new bulb's plastic base making sure that the lock tab is in place.
  2. Install the bulb by inserting the smallest tab located on top of the plastic base into the corresponding notch in the metal retaining ring. Turn clockwise 1/4 turn until it stops. The small plastic tab should be at the top of the metal ring.
  3. Install the composite headlight assembly, then secure with the retainers.
  4. Connect the negative battery cable, then check for proper headlight operation.
Jan 10, 2010 | 1997 Buick Skylark
Want to replace the radiator on my 1997 ford thunderbird
Radiator Aluminum Core, Crossflow — 3.8L (Base) and 4.6L Engines
Removal
  1. Drain engine cooling system as described. Disconnect upper radiator hose (8260) and lower radiator hose (8286) and radiator overflow hose (8075) from the radiator (8005). Disconnect the transmission oil cooler inlet and outlet lines from the radiator.
  1. Remove cooling fan motor,fan blade (8600) and fan shroud (8146) assembly as described.
  1. Remove radiator upper bracket retaining bolts and remove bracket. Lift radiator from vehicle.
Installation
  1. Position the radiator into the vehicle. Install upper brackets and tighten bolts securely.
  1. Connect the transmission oil cooler lines to the transmission oil cooler fittings.
  1. Install cooling fan motor, fan blade and fan shroud assembly as described.
Engine Cooling Fan Motor, Fan Blade and Fan Shroud Assembly, Electrical Removal
  1. Disconnect (pull apart) the male-female cooling fan motor wiring connector at the side of the fan shroud (8146). Remove the male terminal connector retaining clip from the fan shroud mounting tab.
  1. Remove two fan shroud upper retaining bolts at the radiator tanks.
  1. Lift cooling fan motor/fan blade (8600)/fan shroud assembly past radiator (8005), disengaging fan shroud from two lower retaining clips.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten fan shroud retaining bolts to 5.2-7.2 Nm (46-63 lb-in).
    8d231fe.gif HOPE THIS HELPS.
    Oct 30, 2009 | 1997 Ford Thunderbird LX
    I need a pull chain DIMMER switch for my fan light. Only one set of wires supplies the fan and light. Surely SOMEBODY has a pull chain dimmer ??? Thanks. Bill
    Bought three fans for the bedrooms, all hunters with pull chain dimmers. Less than one year and two of the three dimmers are shot. Can't find a replacement so I bypassed it. Remove light assembly and unplug 9pin connector. Remove black vented dimmer assembly by removing wire nuts and disconnecting the 2wire connector(black and white wires). Cut the 2wire connector off and save it in case you find a part someday. Wire nut black to black(hot) and white to white(neutral). You will disable the pull chain by wire nutting those two wires together.
    Jul 29, 2009 | Hunter Ceiling Fan Light Switch Control
    Hampton Bay 46056 Callaway II Ceiling Fan Logo
    52 people viewed this question
    Top Hampton Bay Dryers Experts
    Steve
    Donald Klecher
    Donald Klecher
    Level 1 Expert
    Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
