Black vertical mark on computer
My monitor has a black veritcal line on it which i thought was scratch but now i don't think so. can't feel a scratch and i think it has gotten bigger. i tried the eraser and the vaseline for a scratch and that doesn't work. it did happen after i moved the computer but i still do not think i scratched it
    Problem Solver:
  • 16 Answers
If it is an LCD monitor it sounds like the monitor got cracked when you moved it. Either that or one of the edge connectors has gotten damaged and is causing a dead column of pixels.
One other possibility is a bad video card or video cable, hook the monitor up to another computer and see if the line is still there, if not, video card or cable. If line is still there then there is either a crack or bad edge connector. Crack there is no fix, except a new monitor. Edge connectors can sometimes be repaired by the appropriate service technician.
Good luck
Posted on May 10, 2009
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Veritcal streak on left side of paper. Streak is light gray
Vertical streaks are usually caused by a bad fuser. The fuser roller has a teflon caoting and when this coating gets scratched or worn it causes image defect to appear on the paper. The fuser for the 4250 is part number RM1-1082 and you can get them from Amazon.com or other online sites. Here is a link to an article that shows how the fusers can cause the vertical image defects like you have.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Feb 12, 2013 | HP 4250 Monochrome LaserJet Printer
When watching movies on my computer, I am getting a weird line through the middle of the screen at times, also, when things are moving on screen faster, more lines seem to show. I guess they don't really...
i think your vertical IC ( if vertical lines are shown) / horizontal IC ( if horizontal lines are shown) of your monitor has damaged. you may contact a mechanic and change the corresponding IC
Sep 16, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Prints thick black lines
Hello, Andrea.
Sounds like either your printer needs a new fuser assembly (If the teflon roller gets scratched or starts to disintegrate you will get lines or black marks on the page) or you need a replacement toner.
Hope this helps.
Sep 14, 2009 | Brother HL-5240 Laser Printer
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Vertical lines in the screen of the monitor
Lines called "Tab separation" . Needs new LCD
Mar 19, 2009 | HP Pavilion dv6000z Notebook
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
Repaire scratches on a lcd flat screen
The eraser method is even better than I first thought.
I acquired my first scratch some weeks back, tried the eraser method, and was quite pleased with the results, as my scratch was approx. 80% less visible, a faint grey line visible only on very light or dark coloured backgrounds, instead of the glaring black line it was at first.
Today my monitor toppled again (I really must tether the damn thing to something next time) creating - gulp - a new and even larger scratch. Oh, no... But whodathunk I'd end up happy I got the 2nd scratch? Oddly, I am happy, 'cause I took the opportunity to lay the monitor flat, take my white eraser again , and really go to town rubbing both new & old scratches. Lo & behold, both scratches appear to be now virtually 100% invisible or gone. My 2-scratch monitor is better now than it was as a one scratch one! I'm now convinced it's partly, largely, or completely due to the heat from friction of rubbing the eraser across the scratch, plus pressure applied, that does the trick. The heat must soften the plastic surface making it malleable, and the pressure of rubbing smooths out the jagged scratch edges, making the scratches disappear.
-So, if at first your eraser doesn't completely eliminate your scratch, try, try again! Keep working on it - harder!faster! And with luck, you'll get results like mine: complete elimination of two ugly scratches!
Apr 25, 2008 | Computers & Internet
Toshiba 46HM95 46 tv
If the line is all that is showing with black on the top and bottom. This indicates a loss of vertical deflection which is caused by the loss of the veritcal sweepignal. Check the output of the vertical section of the TV set. You will need an oscilloscope, and multimeter along with a schematic.
Oct 01, 2007 | Toshiba 46HM95 46" HDTV
Computers & Internet Logo
192 people viewed this question
David Payne
David Payne
