Question about Pyle PLA600 Car Audio Amplifier
Protection red ligth comes on.
I did replace those output transistors and still doing the same problem
  • 532 Answers
Are you over-loading the input channels?the rca cable input can only take O watts or really low watts
Posted on May 10, 2009
Protection mode is on and I don't know why... Red light on the amp
Protection mode normally actives due to too much current being drawn by the output amplifiers. This can be caused by improper loading ( impedance too low for amp to drive) or one or all of your output transistors are blown. The protection mode monitors the power supply current and thermal properties of the power amp. Since your problem happens when it turns on I would have to say the supply is drawing too much current because of a bad output transistor. Without troubleshooting the amp this is the best answer I can give you. Good luck!
Jul 19, 2011 | Sony XMGTX1852 Car Amp
Audio and picture go dead red light blinks 7 times
A protection circuit has cut in - possibly due to a fault in the line output stage (flyback transformer could be short-circuit and horizontal output transistor could also be shorted).
Assuming the power supply/HT rail is all OK, replace the above parts, touch up any suspect solder joints, check and replace any capacitors (electrolytic and the tuning caps in the collector of the horizontal transistor - always replace these caps (rated at around 2kV - 6kV) whenever you replace the flyback)
Jan 24, 2011 | Sony FD Trinitron KD-36XS955 36" TV
Power seems to cut in and out - it 'clicks'and a second red light comes on - most of the time just one red light is on. Thanks
The click you hear is most likely the speaker protection circuit relay due to the protection circuits being triggered. In the event of a dc voltage appearing across the speakers the protection circuit isolates the the speaker terminals from the output stage.
Dry joints on the relay is not uncommon and causes false triggering. Check both pos' and neg' supplies are present at the output transistors / ic. Connect a dc volt meter across the speaker output terminals if a voltage of more than a few millivolts appears just before relay clicks then check the ouput stage for dry joints, leaky transistors and resistors having increased in value.
Mar 05, 2010 | Audio Players & Recorders
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
Well my amp comes on but it doesnt give out like bass power or its jus not working like it use to the light comes on orange or red
Note:
Dec 30, 2008 | Visonik V4208 Car Audio Amplifier
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
No picture
This set is a projection tv with 3 tubes red,green,blue more then likely 1200pf 2kvolt capacitor,hori output transistor.
Dec 06, 2008 | Panasonic PT-47WX53 47" Rear Projection...
PROTECTION LIGHT
Disconnect the speaker wires and the RCA cables from the amp. If the protection light still comes on, the output transistors have likely failed.
Nov 02, 2007 | Lanzar VIBE531 Car Audio Amplifier
Power don't turn on
Look for a large aluminum heat sink with the output transistors bolted to it. You should see anywhere from 4 or more large transistors bolted to it. I doubt that the protection circuit is malfunctioning. I would bet that it is doing exaclty what it is supposed to do. If you do find some bad output transistors, be sure to check all the components that work in conjunction with those transistors. Good luck.
Apr 07, 2007 | Denon AVR-1400 Receiver
Pyle PLA600 Car Audio Amplifier Logo
52 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
