Question about Car Audio & Video
Speaker rattles. The cover on the speaker has come unsealed.
    Problem Solver:
  • 7 Answers
Are these after market speakers or original cloth trim covers. if they are aftermarket metal covers in a plastic rim a small amount of glue or double sided tape should keep them from moving, if they are cloth trim covers check the tabs at the back of the cover to see if they have broken due to wear. if the tab is still intact you will need to pop the door trim off and push the cover back into place then bend the smaal tabs back to meet flush with your door triim again.
Posted on May 30, 2009
On one of my speakers, bass frequencies break up, make a rattling sound.
This could be a defective cone, possibly "popped". Also, an inexpensive speaker may begin to rattle after having been driven too hard.
Feb 15, 2015 | Audio Players & Recorders
Rattling in left earcup
Sounds like you have blown out the cone on the speaker. Have you removed the covering to see if the speaker in that earphone is intact?
Feb 10, 2014 | Bose QuietComfort 15 Headphones
Speaker rattle
yes try to change the speaker
Jun 18, 2017 | Samsung Cell Phones
Can you fix a rattling speaker with silicone spray
Yes You Can. But its not recommended on subwoofers or any larger speaker that moves a lot. The only way this will work is if you can see the foam rattling and its not a huge rip.
Aug 08, 2012 | Pyle Car Audio & Video
Rattle when deep base played
If you can remove the rear cover check to see that the speaker mounting screws or nuts are tight. If they are the speaker is blown or defective. I would contact Boston Acoustics if it may be still under warranty or can be repaired. good luck
Apr 14, 2011 | Boston Acoustics VRS Pro Surround Speaker
Sub makes rattling sound
You may have a loose speaker support in the speaker cabinet.
One of the speaker support screws may have come loose and is vibrating against the case.
May 12, 2010 | Altec Lansing VS4121 Computer Speakers
I want to disconnect the factory sub-woofer from the factory radio.
generally the speaker cover panel will 'pop' off with a little gentle prying, giving access to the speaker itself which will allow you to simple pull the wire leads. I would suggest taping them so they don't cross and cause hiss in your system or rattle inside the speaker containment area.
Nov 13, 2009 | 2001 GMC Yukon XL
Kinyo t3100 bass speaker has a rattle when playing music
try turning the bass down and make sure that the rattle is inside the speaker check around it and see if its not something nearby the speaker it could be something came off inside.
Oct 08, 2009 | Kinyo NB-100 Computer Speakers
Rear speaker rattles in 02 Montero Limited
That cover doesn't come off - It's screwed (4) from behind. You have to take the upper trim piece off (and handle) to remove the bottom trim piece and access the subwoofer. If your sub is like mine, the foam all the way around the sub has torn away, making it rattle. There are only 4 screws holding the sub in place, and it's sticky taped to the wall, so you may have to pry it off. Hope this helps!
S
Aug 29, 2009 | 2002 Mitsubishi Montero
Right speaker has a zzzzzzzz sound
Your speaker might have a loose housing. To check this, try shaking the speaker up, down, and side to side gently and see if you hear any rattling. If you do, and you are good with opening things and electronics, then look at the speaker all around and see if you see any screws. If you do, then take them out and carefully separate the halves, front, or back (it depends on where the screws are). If you do not, then there should be a way you can pop the front protective cover off that protects the speaker from foreign objects. You should be able to look through the second protective cover (if there is one) and see the speaker. Try playing something and see if you can find the source of the rattling. If you can see a tear or all that you see is the speaker shaking when you hear the sound and you did not here rattling, then you may need a new set of speakers. If you can, try to tighten the housing.
Nov 08, 2008 | Logitech X-540 Computer Speakers
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
