Is many things which can result in not starting.
1) check if ur starter motor cranks if it does ,check for spark.
2)if the starter doesnt check your battery state by using a multimeter take the readings if is 12,00 volts or more is good
3)check your battery terminals contacts against the battery poles if bad use hot water pour over them but extra careful is needed because some of electronic component hates water
SOURCE: i need to aquire mitsubishi dion 2000 model owners manual. pls help, thank you!
try auto zone .com no gaurentee but they have had all manuals for the ones ive looked for
SOURCE: I need to clean mass air flow sensor for Mitsubishi Dion
give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
SOURCE: why does my mitsubishi dion 2000 model engine does not start once when i start the engine
need to check battery if it is fully charge then the starter.
consider the engine oil if it has no mix of water(coolant).
good lubrication makes the engine easy start.
after this checking if it is not run, the problem may be at the engine.
SOURCE: I have problem with my mitsubishi dion 2000 model idling not very good when i start the engine
need to check ignition coil(s) pack.
and i suggest to have technician with scan tool to diagnose properly and solve the problem.
