Question about Garden
Which way do you turn the bolt to remove blades on a yardmachine 38" riding lawnmower deck. Its a 12.5 hp motor and has 2 blades on the deck.
  • graceave May 10, 2009
    thats what i thought just wanted to confirm thanks for the info now ill go do it
    worked great thanks for the info all set with the new blades unfortunately wasn't able to sharpen the olds ones to far gone
    Problem Solver:
  • 14 Answers
Turn to the left.....while holding the blades still....If it is hard to do, then use a wrench and beat it with a hammer...or use and air impact wrench.
Posted on May 10, 2009
  • num1wrench
    num1wrench May 10, 2009
    10-4 Thank's for letting me know
  • 98 Answers
The oppiste way the blazes spin it is set up that way so the bolt will stay tight
Yardman troubleshooting
I suggest that you should remove deck, turn upside down and place straight edge or tight string line over blades from outer edges of deck frame. Use the guide strips to get even measurement. Rotate blades and measure distance from straight edge to tips at both sides. they should be the same. If there is difference from one side to the other, either the blades are bent, or if each blade is same at each end but not aligned in centre (difference in height) then the spindles need packing to make them even. Check that bearings are not loose. If you do not understand this best to take it to service centre.
Jul 23, 2014 | Yardman Yard-Man 13AC76LF055 38-Inch 344cc...
Have Poulan riding mower with 135 cc motor. Battery is full charged but the engine is not turning over. starter is not turning at all
Check the safety switches, especially the blade safety switch, people forget that one. Blades must be disengaged to start the engine.
Aug 14, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I need to repalce my blades and i have the model number but cannot find the blades online.
Your Poulan riding mower was made by American Yard Products. For the AYP 38" mower, you have 2 options for blades. 1. #131322 heavy duty blade 2. #193957 mulching blade. You should be able to order these thru www.searspartsdirect.com also try www.amazon.com
Aug 25, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a Craftsman LT riding lawnmower and for some reason the one of the blades is a very loud noise. I have tried going under the deck and tighten up the bolt that holds it in place but it still making...
Check for foreign objects caught under the deck, as well as for a bent blade. If that's not the problem, look at the mower deck belt - is it burnt or worn in a spot? Take it off, and see if you can turn the blade spindles and idler pulley freely. If they scrape badly or are frozen in place, that's the problem.
Jun 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Do you have a diagram for how to install a deck blade for a poulan 15.5 hp 38" 5 speed briggs and stratton
If you are refering to the actual blade and not the entire hub assembly then it is real easy. Just take out the one bolt in the middle of the blade and put your new blade in.
May 04, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Aug 08, 2009 | Garden
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
