Question about Samsung SGH-T429 Cellular Phone
It fell into a puddle and now it only starts when it is charging
    Problem Solver:
  • 10 Answers
Maybe if you clean the the battery and battery terminals with a clean dry cloth and then put it in a bowl of uncooked rice it will work. Please give me a rating.
Posted on May 10, 2009
Car wont start makes noice like battery do when dead what do i do to fix and start it
Charge battery lol unless your shure its charged , take bat connections off , use a can of Coke pour on batt terminals , ( a small puddle on each don't pour it all over the car )....wipe down with sand paper any grit do same to inside connectors ...wipe up liqude if any left , fasten connectors down good again
Nov 09, 2015 | Cars & Trucks
Engine diagram
engine diagram. of what? the FSM is full of them.
something fell off?
what, is it. post a photo, or link use to a posted site or cloud or photo bucket , photo.
does engine starter crank? fast and normal
are all fluids at proper levels, engine, and coolant?
did you check your antifreeze percentage with a gauge every fall?
the tools is $2 and takes 1minute every fall to do..... 50% ratio is good.
is childs play easy.. ask.
1: check all fuses in both fuse boxes.
2: check fluild levels. (engine oil, and coolant)
3: make sure antifreeze coolant is not pooling (puddle) below car???
4: now does engine crank? , fast, yes.
5: does it start , no.
6: does engine have spark at all cylinders. (a test)
ask for step 7 to 50,,, we have it. each test.
Jan 03, 2014 | 2000 Honda Odyssey
I was letting the engine run to charge battery after a a jump start when smoke and steam were pouring out. also noticed water puddle under car
You have overheated the engine, check the engine cooling fan operation there is a problem I suspect.
Apr 08, 2017 | 1999 BMW 323 Series
Serpentine belt fell off
Belt falling off,, It is most likely a belt tencher, or a pulley,, Turn pulley's by hand felling for any wobbling or play side to side especially watter pump ,if fault is found replace part and reinstall belt,!if you cant find fault,Reinstall belt,then pull on belt to see if it belt has tension and returns with no sticking of tension-er then,if all look well .start car and observe ,may have been a glitch or bad belt best wish
Mar 21, 2010 | 2006 Pontiac Grand Prix
My car wont start, the light on the dash come on and the clock turns on but there is no noise I did drive through a huge puddle on my way home. Could this be it?
Check that your batterie is fully charged, if it is then it is possible that the huge puddle could have damaged your starter. to check if you starter is ok your going to have to remove it then take it to your local parts store and have them test it out. Hope this helps
Feb 26, 2010 | 1999 Chevrolet Cavalier
Hi. Have an env. Have it in a silicone case. It just fell on the drive - in a puddle which did not cover the phone. Immediately picked it up and removed the case. It really was not wet at all. I took my...
the screens have probably been damaged, i would try taking it to verizon so they can make sure and so that your phone doesnt get anymore problems from the puddle.
Dec 02, 2009 | LG enV VX9900 Cellular Phone
Phone fell in puddle
Sadly I think it is too late to help. If it had water inside, that probably shorted it out. However, in the future, you should take the battery out as soon as possible to prevent this.
If you want to try something, just let it dry completely and then try using it again. I doubt that this will do anything, but it might end up working.
Mar 04, 2009 | Sony Ericsson w580i Cellular Phone
I dropped my MP3 player in a puddle of water. I
Even drying doesn't usually help. Water kills electronics - period. That is the only solution I can offer, because that is the only correct answer.
-Tha Mp3 Doctor
Dec 18, 2008 | RCA OPAL M4001 MP3 Player
Samsung SGH-T429 Cellular Phone Logo
56 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
