Question about Kenmore Washing Machines
No power when pushing the power button on my washer
It's pluged up and outlet works.
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    front loader or top loader??
  • 56 Answers
Try a resistance check on the input and output connections on the switch,the thicker feed wires going in and out of switch, when its plugged out,these switches carry heavy loads and can fail often,follow local safety guidelines when working on electrics hope this helps
Posted on May 10, 2009
Is there a fuse on model no jvm1540dn1ww
There should not be a fuse on your washer- what is usually the problem here you have a reset button the power cord- also be sure to check if you are plugged to a GFI circuit-
if this is the case unplug the power cord-
reset the GFI outlet (wall plug)-
plug your power cord back into wall-
and push in the reset button-
TY,
perrytradesman
Aug 13, 2014 | Karcher 2500 PSI Pressure Washer
Plugein but no power
Check power outlet is working by trying another appliance, if it is ok you will need to either get a qualified engineer to trace the voltage through to see where it's failing. If the power outlet and flex are ok next step is the on/ off switch, and any fuses/safety cut outs . Alternatively if you disconnect it you can check continuity with a test meter . Caution high voltages when connected to the outlet.
Apr 18, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I pushed the wrong button on my remote and now my Akai flatscreen says no signal. But I don't know what button I pushed! Please help!
Unplug TV from power outlet ,wait 5 min and pluged back.Should go back to manufacture setup
Cheers
Aug 23, 2011 | Televison & Video
There is no power on the machine outlet works breaker works
Very likely there is a GFCI type outlet somewhere in the kitchen/bathroom or even garage if you have garage that has a reset button on the outlet find that outlet and push the reset button.
Gene..OldTech2332
Aug 18, 2011 | GE Spacemaker WSLP1100D Top Load Washer
DE PUSH POWER BUTTON POWER COMES ON GOES RIGHT BACK OFF, IF YOU HOLD POWER BOTTON IN AND TURN KNOB TO A CYCLE THEN PUSH START BOTTON ERROR dE COMES UP
Check the outlet first. If the outlet is ok, then you have a control board issue. Replace the control board. Good luck.
Jun 19, 2011 | LG WM2487H Front Load Washer
Off balance alarm sounded as always I rearranged load closed lid pushed start pause button . Display lites all went out . Washer display will not function . Acts as if washer is not pluged into outlet It...
Hi just read your posting.Now if the machine does not light up when you turn the power off then on at the outlet then either your pump is open circuit or your control module is faulty.Now if you have or can borrow an electrical test meter I can help you in the testing of the pump to see if this is the fault.This will narrow down where the fault is and then I can guide you step by step in rectifying the fault.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a cabrio washer wtw6200 when i push in the start button will not do anything. it like the senser been push inside.
First check to see that you have power in you outlet. If so then you can check under the control hood and see if the 120V line comming into the motor control unit is pluged in and seated correctly.** UNPLUG FROM OUTLET BEFORE YOU CONTINUE** To get to this there are about 6 screws on the back behind the control hood, leave the bottom 2 screws on the pivoting clips.Move that galvinized panel back a little, then grab the whole top and slide it forward and lift the front edges. Once lifted there are 2 clips under the cover to release the control hood, Lift it off and you can check the 120v and all other plugs for correct position. Re assemble and try it. Good Luck
Jun 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not start
this may or may not help but double check that the outlet that is being pluged into is first not the outlet for the garbage disposal, and second that if ist a GFI outlet that the reset button is pushed in.
Feb 09, 2010 | Dishwashers
No power to Maytag Dishwasher MDB-8
no breaker on motor look at door lock ***. for power
Nov 03, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Washing Machines Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
