Question about Dryers
Heating good, venting good but takes two or three times to dry clothes
Heating element is good, good vent but takes two or three times to dry clothes.
  • wildtamarind May 10, 2009
    the washer is spining fine, could it be a foulty temp switch?
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    Are the clothes wetter than usual going in? sometime it's the washer that isn't doing it's job getting the water out first...
    let me know.
    KEN
  • 56 Answers
Sounds like theres a burnt link on your elements,if for example you have a 2000watt dryer you should be getting 9amp for 220v supply 18amp for 110v supply,watts =voltsxamps,amp clamp the feed wire to check,if you have a half heat switch that could also be problem,ask a competent electrician to do the above checks,hope this helps
Posted on May 10, 2009
Dry takes a long time to dry cloths
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Kenmore Dryers
Needs two cycles to dry clothes!
May 19, 2012 | Kenmore Dryers
Takes long time to dry
May 16, 2012 | Kenmore Dryers
Indesit IS70C tumble dryer not heating
May 10, 2012 | Indesit IS70C Electric Dryer
No heat/Only works on one setting
May 08, 2012 | Roper Dryers
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Clothes won't dry
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryers Logo
Top Dryers Experts
