Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No picture Mitsubishi VS-70705 loses picture but has sound
  • 1 more comment
  • Bill Hurst
    Bill Hurst Nov 03, 2007
    the sound works,,the guns power up,,,but thay dont fire.......
  • Cfranks May 25, 2008
    My TV has excellent sound system but just no pictures. What can I expect from the repair service as far as what's wrong with my TV.
    Chitra
  • Anonymous Jun 04, 2008
    the sound work but no picture
When I first turn the tv on the picture comes on for a few seconds then the screen goes to green but I still have perfect sound
Posted on Oct 13, 2008
When i turn on my tv the first ting it says is to eneter a code..
and i have no idea what it is.
i have a mitsubishi 625526-2006
tank u
Posted on Dec 24, 2008
Static. cannot get picture without lines and staic
If you haven't already try setting the convergence board, another thing that can cause that is old electrolyte in your picture tubes. Before you change the electrolyte find a small rubber diafram about the size of a half dollar and pump them it stirs the electrolyte and sometime it will restore it and straighten up your picture. Hope this works dhgill1949
Jun 04, 2011 | Mitsubishi VS-70705 70" Rear Projection...
Trying seperate the base from the top for moving
they do not seperate because the base is where the color guns are located so that is why you cannot remove it.
Feb 26, 2011 | Mitsubishi VS-70705 70" Rear Projection...
What causes the image on the screen to jitter
Sounds like bad convergence ICs. They are complicated to replace but a good tech should be able to do it for about $100. Let me know how this works out.
hardrocko
Jan 31, 2010 | Mitsubishi VS-70705 70" Rear Projection...
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
VS - 45065 Rear projection TV
hi .
All the models listed on the manual are all the same chassis as yours. when there are more then one model listed it means that there are a few different variations of this unit, normally it refers to the screen size. if your set for example is a 51 inch unit then look for the model closest on the manual.
yes the wii and other gaming units are fine to use with a rear projection television. the only thing to watch for is not to pause games and walk away as this will cause screen burn.
Jul 09, 2008 | Mitsubishi VS-45605 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Lose picture
most likely bad connections check the vertical output ic
Jun 20, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50705 convergence problem.
There should only be a couple of STKs, the R's are resistors, they STKs should cost under $20. This should be everything you are looking for. If you need anything else, let me know.
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
Ref # / Part # / Part Name & Description
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
Jun 05, 2008 | Mitsubishi VS-50705 50" Rear Projection...
How to disassemble a VS-70705 for transport
I found the problem. Mitsubishi put 2 strips of what looks like rubber caulking inside, presumably to keep the TV from rattling or something. Peel them off from the inside and the top comes off just fine. Both pieces are still very heavy, so its at least a 2 man job moving either piece. Most of the weight seems to be the LDF more than the TV though.
May 25, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
