Press function to select clock
press function repeatedly until clock appears on display
press < or > arrows to select part of clock to adjust
press Up or Down arrows to change hour/minute
Here is the address link for a download for your exact owners manual:
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/ci.OPERATION+MANUAL+DEH-P6600+20040225.Protected
SOURCE: setting clock on my pioneer deh 1400
the radio must be turned off with the ignition key in the on position... then hold the function key for about 3 seconds if it doesnt have the function key try the audio or source button one of them will bring you to a menu, once in that menu use the func key to scroll though options until you see the clock flashing.. use the up down left right keys to adjust these different options...
SOURCE: setting clock on pionerr deh-p3500
try www.pioneerusa.com you can download the manual for this model -----
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Go to the link below then scroll down to product details. Then click on product manual. On page 32 it will tell you how to set the clock.
http://www.amazon.com/Pioneer-DEH-P6600-player-Full-DIN-dash/dp/B00025YP6S
