Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony KDF60-WF655 Picture will not turn on
Can anyone help me how to fix this kind of problem? The power is hooked up when I turn my TV on, the power green light flashing goes on for 5 times a then turns to a flashing red lights 6 times. I replaced the lamp and blow all the dust in front and back of the TV. And thanks in advance.
  • arnewal May 10, 2009
    I did that but still doing the same things flashing green light 5 times and red light 6 times and keep flashing red lights 6 times. Any alternate solution?
  • arnewal May 14, 2009
    I just call service technician to solve the of my TV, very complecated for me. anyway thank you very much.
    Brigadier General:
  • 3,614 Answers
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Let me know for further clarification.
Posted on May 10, 2009
  • micromaster
    micromaster May 10, 2009
    Sony TV’s have a built in self-diagnosis function. If the timer/standby
    indicator is blinking, this could be an indication of a problem with
    the unit. The diagnostic blinking will occur automatically with no
    action required by you to engage it.
    Five blinks - AKB circuit (automatic kine bias), the
    timer/standby indicator blinks for about 30 seconds then goes to the
    self-diagnosis function. Something is wrong with the video. Check video
    out, Q705, 732, 761 and other components on the C board, also check
    Q218, 219, 220 on the A board. In addition, unit could be in IK
    blanking, try turning up screen slightly.
Blue clouds on screen, already replaced main bulb still getting worse. Please help.
Light Engine is Bad, Sony had alot of these that went bad. Sony Offers replacement TVs if this is the case. Go to Facebook and then type in I HAVE A DEFECTIVE SONY TV. Sony has a FB account and they will get back to you about a replacement TV. Sometimes they will offer you a 55inch LCD in replacement on the old DLPs.
Oct 08, 2012 | Philips Sony Kdf60 Wf655 New Lamp 1 Yr...
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
My sony wega kdf-60-wf655 is blinking 7 times but when i try to start it, i ear some kind of power sound then goes off, i have disconnected evrything but still does not work
f-9308-750-0.jpgTHIS IS WHAT YOU NEED THE LAMP found behind TWO covers on side of tv one clips off the other needs to be unlocked by turning leaver and pull out this one is a SATETY COVER now reach in and lift the latch on the lamp and slide out REFIT AS REVERSE make sure safety cover is locked in place tv will not work if not ( LAMP XL-2200 )about £120 new
Oct 24, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Sony KDF-WF655 HDTV Red light on Power/Standby Blinks 6 Times
This is from a repair Manual. You may not be able to do all repairs yourself.
Apr 20, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
KDF60-60wf655 lamp relacement problem
Make sure you have the lamp seated correctly
If you used a non sony lamp it may not be compatible
remove the lamp and look to see how the two connectors line up
they are the most important
Jan 27, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
No picture connected via HDMI
Your PS3's HDMI settings may be the issue. When you go to turn on your PS3 next time, instead of just pressing the poser button and letting go, hold it for 5-6 seconds until it beeps again and then let go. This will force the PS3 to autodetect your TV again and should bring up the video. good luck!
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Sony kdf55-wf655
I hit the "display" on the remote for the Sony TV
Jan 23, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
PS3
make sure you've changed your TV from TV to video, and that the video that you have on your television corresponds to the one that you plugged into the back of your television. we just had the same problem with ours - any help?
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
No picture no sound
Could be a bad relay, or a bad power supply, or something else. Unplug the TV for a while (overnight perhaps) to see if it "resets
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Oct 10, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
