Kitchen Aid 4450786A (Microwave/oven combo). Unable to use Microwave. When door is closed, it still reports that is open and will not allow to start. Is there a latch or sensor that needs to be replaced/repaired?
There will be a technical sheet hidden behind the controls which will help you locate major components.
The marked diagram below shows you the various parts that can fail and what effect will result.
You can find helpful exploded view diagrams and order parts by part number here.
Check the two fuses first, then if you have to check the cavity TCO, you will likely need to remove the oven from the wall.
If for some reason you don't still have your installation instructions, you can get them - and the parts list - here.
SOURCE: Directions to remove and open door panel to repair safety door latch.
You don't have to remove door to remove panel. Panel is held in by an outer plastic retainer which can be removed by carefully prying with a small screwdriver. I can be replaced by pushing it back in place after repair is completed. If you cannot open door from the outside, remove cover and you can see latches. Pry up on latch which will let door open.
SOURCE: panasonic s550bf Door Latch
Do you still have the piece that broke off? If so, you may be able to use two part epoxy to glue it back in place. I did this with a colaric MW and it did the trick. The latch was hook shaped and made from a hard plastic. Pete
SOURCE: Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
SOURCE: How do i replace door handle
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part number for the model number you provided varies depending on color, so make sure you order the correct one for your oven. You can view an exploded view of your microwave door here:
http://pcappliancerepair.com/model-display.php
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you
Full Unit MODEL # is YKEMC308KM01. The rest of the unit (oven) works fine. The keypad is accessible, not locked.
