Question about Apple iPod nano
IPod won't turn on
I bought an ipod nano just yesterday. i already transfered songs from itunes. the problem is, when i remove the ipod from the computer, it can't turn on by itself. i have to pliug it into the computer so that it will turn on
  • 342 Answers
If this is a new iPod, then take it back to the retailer. Your battery is no good. If it is used, there probably is not any kind of warranty. However if you want to replace the battery it is really easy. I have a web page that you can purchase a battery replacement kit as well as full detailed instructions. There is a video on the second web site listed. However i do suggest following the written instructions as leaving everything else connected can make it a hassle. :) If you have any other questions about this or difficulties with the resolution please do let me know.
iPodbatterydepot.com
www.fixyouripod.weebly.com
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
Simply do every thing in reverse to put the iPod back together. Make sure to remember that it only takes gentle pressure to remove and replace the parts.
Posted on May 10, 2009
Transfer playlist from Itunes to Ipod Nano
Open iTunes and plug in your iPod. On the left sidebar there should be your iPod name (If you can't find the sidebar, go to iTunes menu bar, under View, select Show Sidebar), go to your iTunes playlist and drag the songs you want to your iPod. For all of the songs, go to your iPod music library, even if you don't have songs, and on the bottom there should be a blue-ish bar. There might be a box saying "Autofill from iTunes library" click that ONLY if you want ALL songs from your iTunes to your iPod.
If you want to know how to put video or DVD movie onto iPod, I think this step by step guide would help you.
http://www.dvdintoipod.com/how-to-convert-dvd-video-to-ipod.html
Hope it helps. Feel free to email me if you need further help.
Dec 10, 2013 | Apple iPod nano 3rd Generation
How to down load a song to my appleipod nano 2gb?
To download songs to iPod nano: m Simply connect iPod nano to your computer. If iPod nano is set to update automatically, the download begins. Important: The first time you connect iPod nano to a computer, a message asks if you want to transfer songs automatically. If you accept, all songs, audiobooks, and other items are deleted from iPod nano and replaced with the songs and other items from that computer. If you don’t accept, you can still download songs to iPod nano manually without deleting any of the songs already on iPod nano. While music is being downloaded from your computer to iPod nano, the iTunes status window shows progress, and the iPod nano icon in the Source list flashes red. When the download is complete, a message in iTunes says “iPod update is complete.” If you set iTunes to download music manually, you can reset it later to update iPod nano automatically. For more information, see “Updating iPod nano Manually” on page 22. To reset iTunes to update iPod nano automatically with all songs and playlists: 1 Open iTunes and select iPod nano in the Source list. 2 Click the Options button and click Music. 3 Select “Automatically update all songs and playlists.” The download begins automatically.
if you need further assistance please let me know. Thanks, MIDWEst-tek
Aug 31, 2010 | Apple iPod nano
Howmdo i download itunes songs to my ipod nano
You just need to import your song into iTunes library, then make a playlist with the songs, plug in your iPod to computer, iTunes will detect the iPod automatically, then click iTunes menu "File -> Sync iPod", the songs will be transferred from iTunes to iPod.
For more tips about iPod, you may refer to this iPod FAQ. http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html Hope it helps. Contact me if you have any other question.
Dec 26, 2009 | Apple iPod nano
How do i transfer muisc saved on my computer to my ipod nano
open up itunes and the music library tab then drag and drop your saved music into itunes the music will take a little while to load but after it does you will be able to sync it to the ipod
Sep 30, 2009 | Apple iPod nano
I have an ipod nano 8gb, i'm trying to put my songs i have already saved to my computer onto it, but can't seem to do it do you have any advice ? Thanks Oz
This ipod manage software can transfer the files from ipod to computer,computer to ipod,ipod to iTunes,ipod to iTunes, and iPod to iPod:
please click here for more details.
Hope this Helped!
Sep 06, 2009 | Apple iPod nano
How do i put movies or videos in my ipod 4GB?????? plz
only 3rd generation iPod nanos can play video, and the video must be mp4, you can use itunes to sync video to ipod nano, just follow those steps:
1. Open iTunes and click "File" to add your videos to iTunes library.
2. plug in your iPod Nano to computer, then iTunes will detect your iPod Nano as a device.
3. Select your iPod Nano device on the left panel of iTunes, click "Movies" tab, check the videos you want to sync and click "Apply"
Jul 22, 2009 | Apple iPod nano
Cant transfer songs to my ipod nano
hi the problem may be due to the variation in the format of song. it will not be supported by your ipod nano. pls rate me
Jan 18, 2009 | Apple iPod nano
Basic Transfer of Songs on my computer to White 4GB MP3
http://www.askdavetaylor.com/how_do_i_put_music_on_my_apple_ipod.html
Dec 01, 2007 | Apple iPod nano
Apple ipod
go to itunes.com and dl itunes + quicktime. install and scan pc for songs if u already have songs, otherwise, go to the itunes music store in itunes and buy + dl some musin. plug the cable into your ipod and computer, and transfer
Nov 07, 2007 | SanDisk Sansa e250 MP3 Player
Nano skipping song
Hello there! Wow... sounds like you've really been through the proverbial wringer with this issue already! You have indeed tried almost every step I would have suggested already, but here's another thing or two to try: 1) Burn an audio CD of this song. It's a true waste of a CD, but fortunately CDs are quite inexpensive! 2) Eject the CD. 3) In iTunes, find the problem song and add something to the title to make it differentiate it... for instance, if the song was, "Freebird", I would rename it, "Freebird CORRUPT". 4) Re-insert the CD, and now rip this new version of the song into iTunes. 5) Sync up your iPod and see if the issue is resolved. Hope this helps you out! =)
Jun 08, 2007 | Apple iPod nano
Apple iPod nano Logo
155 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
