Question about Alpine MRP-F300 Car Audio Amplifier
Subs have almost no sound coming from them
My subs have very little sound, can't even tell their on unless you put your hand directly on them. The amp is a brand new 4 channel Alpine f-300, that i have bridged for 2 channels. These subs did the same thing with a previous cheap amp. I have the filter set to lp, and i have tried every setting and dial on the amp, none seem to make much if any difference. My head unit does have the subwoofer mode turned on, and i have gone through and adjusted every audio setting on it. They do seem to make a little more noise if i turn the bass all the way up on the head unit, but then my full range speakers distort easily and i can't get much volume out of it. The subs and the amp are both 4 ohm, i even ohmed out the subs and they checked out. I have checked and repositioned my ground. I even tried hooking up other subs and got the same results. All in all i have tested combinations of 3 different amps one of which is brand new, and 4 different subs with all the same result, just a barely audiable beat. The only other thing i can come up with is to pull the head unit and run new RCA's, but since i am getting a tiny bit of sound, i wouldn't think they would be the problem, because that would mean they are sending a signal, like their supposed to. Though other than trying that i'm out of ideas...
  • meow_mix_666 May 10, 2009
    Actually i did get it working today, and it was the rca's. I have 2 of the same amp, one for my subs and one for my full range speakers. Both of my amps have a set of rca pre-outs on them. And since my full range speakers, use the speaker level input wires to get their signal, i ran a set of rca's from that amp, to the amp from my subs and sure enough they both started pounding. So i just abandoned the old rca's coming from the head unit, and saved me the trouble from ripping my dash apart again. Though still one sub pounds harder than the other, i'm not sure what would cause that.
  • 655 Answers
Hello meow_mix_666,
If you have tried different amps and different subs with the same result, I'd definitely suspect that you are not getting enough of an output signal from the head unit. Checking the RCA's and perhaps using a different set of preamp outs would be a good idea.
One other possibility that you may not have considered is to check the phasing. I've run into speakers that had the markings reversed and running the subs out-of-phase on a 4-channel bridged would make a huge difference in the bass.
Hope this helps.
Posted on May 10, 2009
5 Suggested Answers
Mitco39
  • 62 Answers
SOURCE: Alpine mrp-350 amp
1) If you bridge on a non bridged amp your sound will be horrible as they sine waves comming out of the two teminals will be different... I suggest removing the bridge. 2) The gain knob is to adjust when the amp will reach its max volume with respect to the sterio;s volume. 3) the LP filter is a Low Pass filter and its purpose is to eliminate the higher frequencies that do not sound all the well when played over subwoofers.
Posted on Mar 26, 2007
  • 113 Answers
SOURCE: Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Posted on Aug 09, 2007
etirbynnor
  • 655 Answers
SOURCE: The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Posted on Sep 27, 2009
  • 53 Answers
SOURCE: 2 alpine type r 15's 4 ohm dvc and 2 american bass
Option 1 (parallel) = 0.5 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono This set up will blow your mind as your amp will put out 1800rms at 0.5 ohm
Posted on Oct 19, 2009
Putting Subs in a Ford Five Hundred witout replacing stereo syst
yes you can buy higher wattage subs depending on what watt the amp is
Mar 10, 2010 | MA Audio 800XL Car Subwoofer
I have polk amp that is powering 2 12' subs but itis flashing up with low amp/short light with a little buzz noise?
you must check your wiring from head unit back to subs even take subs out of box to make sure no wires are lose 99.9 of the time a wire has come lose which can be bad if your bridging sups as it changes ohms with 1 or 2 subs hope that helps oh and check volts from you batt and check volts at fuse spots and after fuse to make sure your geting at least 12 to 14 volts cheers i just had a ***** of a prob my subs worked but **** bass found out head unit sub out craped out
Oct 16, 2009 | Polk Audio C5001 Car Audio Amplifier
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Jbl subs
One time I had 2 MTX 10" subs that had a rubber surround. I was playing it a little hard and tore the surround pretty much all the way around. I bought some windshield urethane and glued it back together. I got rid of them a little while after that and surprisingly the guy who bought them tell me they still sound great. So the answer is yes and no. Depending on the surround you might be able to get away with it. Make sure that you use something that stays flexible even after setting. Also depending on where the tear is and how big it is, it might not even hurt the sub. I hope I could help.
-Andrew Hawkins
Apr 02, 2008 | Audio Players & Recorders
My amp works but my sub doesn't...!!!????????????
Whats the condition of your amplifier? New , Used, Old?
You might have a blown channel off your amplifier, this may cause little or no sound. You will have some distortion, crackle sound and then maybe nothing at all. What kind of subs are you running to it? Make sure the subs arent blown and check the voice coils to see that they are not torn off the subs , these are the 2 little silver or copper wires that are connected from the speaker connectors to the sub itself.
Let me know what happens?
Oct 21, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
No Sound/ lights flashing on Amp
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Jul 09, 2007 | Sony XM-752EQX Car Audio Amplifier
The first thing to try is disconnecting ONE of the two subs. See if you get more bass with a single sub than with both. If you do, re-connect the second subwoofer, but reverse the (+) and (-) wires.
Jun 19, 2007 | Panasonic MXE CQ-C7401U CD Player
Subwoofer seem to be broke
The one sub that you described is gone, there should be no reistance at all when you push on them. It sounds like you got your gains set to high on that amp (maybe the amp is underated for your subs). When you turn up the gain to high your cause your amp to distort and it can get as bad as sending a pure DV current to the sub. That DV current will blow subs because of all the force directed in one direction. If you think about it the amp takes a DC current and turns it into a AC current which creates the frequecy (rate at which it alternates) that alternating current pushes and then pulls on the sub keeping it within its boundries.
Nov 19, 2006 | Eclipse SW9102 Car Subwoofer
Amp makes subs pop
It sounds like your amp chip has gone bad, here is some thing you can try turn on your unit then start tapping on top of with your finger not hard see if the any of the pops matches your finger taps some times when the chip starts to go out it well act like that.
Nov 04, 2006 | Orion 2500D Car Audio Amplifier
Open Questions:
See all Alpine MRP-F300 Car Audio Amplifier Questions
Alpine MRP-F300 Car Audio Amplifier Logo
290 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
