Question about Onkyo TX-LR552 6.1 Channels Receiver
Onkyo TX-LR552 was working great until I hooked up the tv to act as a set of speakers. It cut off and now won't cut back on. We've unplugged it for a day and still nothing....
  • 11,896 Answers
Could be a couple things.
1. The system has a safety feature that cuts out when to much voltage runs through input/outputs
2. The audio ouputs have fried and will need all new capacitors installed.
Posted on May 10, 2009
  • Nate Stansfield
    Nate Stansfield May 10, 2009
    If the device does not turn on at all, then the problem is a blown bus fuse or bad power supply. You can see them if you remove the cover.
I have an Onkyo TX-SR500. I turn it on, and immediately it shuts off. Under troubleshooting it says, "activated amplifier protection circuitry". Here is my issue: I've called Onkyo USA...
No one would be able to troubleshoot it over the phone or internet. Take it to a reputable shop and get an estimate, then decide if it's worth the cost.
May 17, 2011 | Onkyo TX-SR500 Receiver
I've gone through all of the setup procedures, only the front speakers work, nothing from the rears, center, sub or sides. When setting up with the mic, all goes well?????????????? Onkyo TX-SR602. Tried...
Steve,
I would forget the TV for now. I would use another input source to confirm where the problem is. I would hook up a CD or DVD player to it and check that the speakers are working as they should. If they do work, you may have a bad cable from the TV. Or the new TV is not set for surround sound. It may be as simple as selecting the proper decoder from the TV menu.
Dec 04, 2009 | Onkyo TX-SR605 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Left speakers are not working on my onkyo tx-ds575
Check the units internal "menu" settings for speakers and audio. beyond that, there would be an internal problem and neded service. Hope this helps
Jul 05, 2009 | Onkyo TX-DS575 Receiver
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
Video thru Onkyo TX-RS606 is only black&white
are you using HDMI cables or component. First I would try unplugging the composite and component video cables while the receiver is off. Plug them back in and turn it back on. If that does'nt work try setting the receiver to factory default and redo the settings. You can find how to reset to default in your user manual.
Oct 24, 2008 | Onkyo TX-SR605 Receiver
Loss of video signal from Onkyo TX SR 875
Go to hardware set up and turn off the hdmi audio output,sounds daft but it should work,also make sure the B speakers are not on as this puts the menu up the left.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Onkyo TX-SR503 Receiver
Onkyo TX-DS939
I have to ask the obvoius, did you get the manual, have you used the onscreen menu to set up the speakers, you can calibrate the speaker levels on the TV screen if you use the S video or RCA vidoe connection .have you turned off tape monitor?
Apr 27, 2008 | Onkyo TX-DS939 Receiver
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
Onkyo TX-LR552 6.1 Channels Receiver Logo
250 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
