Question about Ford 8n,9n,2n, Tractor Starter With Drive
I have a 2n ford tractor. Starts great but will
I have a 2n ford tractor. Starts great but will not pull itself up a hill. Any suggestions?
  • 1 more comment
  • d_clevenger May 10, 2009
    Sorry, my tractor is a 1945 2n tractor - 4 cylinders - it starts up, runs great on level ground, but spits and sputters when trying to go up a hill. emphazing trying to go up a hill because it will not pull itself on even a small incline. Could it be the govenor?
  • num1wrench
    num1wrench May 11, 2010
    Please describe how old, etc., and any markings on the tractor, etc.
    Horsepower? Cylinders, etc. etc.
    Does it run OK on level ground?
  • Jim Myers May 01, 2014
    I suspect the float bowl. If the float is flooded or set too low the carburetor will suck air instead of gasoline. I\'d do a caburetor rebuild if you can find the kit. I got mine for my 2N (1946) at a local Tractor Supply store for $14 and it really put new life in it! Next, I\'d check the timing, but that\'s a slim chance since your tractor starts and runs. If the spark were too advanced, it\'d backfire and sputter. If the timing were too retarded it\'d start fine but have little power
  • 246 Answers
Hello
Have you Checked the Point Set Gap?
If the Point Set Gap is Not Set Correctly or the Contacts are Burnt, then you will have this Problem.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
    Problem Solver:
  • 14 Answers
Please check the fuel bowl for water!  If it's finally full of water and you get on a hill, the water will flood out the engine and starve it of gasoline.  same thing with the fuel tank, water from condensation can collect at the bottom of the tank and be ok until you get on a slope and the water will clog the fuel strainer, just a thought!
God bless,
tx tmblweed
Posted on May 14, 2009
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
2n ford tractor stalls when i let the clutch out
Your clutch needs adjusted a little more. Not releasing all the way.
Dec 28, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
Oct 29, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Need to replace 9n tractor starter when you turn ignition key the starter just keeps going around.
I suggest that you pull the starter and make sure the bendix unit isn't stuck on the shaft which may be rusted or dirty and corroded first. If the starter spins then the starter itself is probably okay. Hope this helps you
Oct 16, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 601 cuts out few minutes after start up
Hi..my name is Keith..and i restore 9N's,2N's and 8N's...but the systems are basically the same...so..you know and i know its either ignition or fuel..on the ignition side..i would suspect either the condensor or coil is breaking down when the engine gets hot...and on the fuel side..if you have already cleaned the carb..i would suspect trash in the fuel tank or trash in your sediment bowl and valve..which can be cleaned or replaced..i hope this will help..its the simplest thing to check or replace..if it didnt help..please write back
Jul 01, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
8n tractor runs good at first then after awhile starts to sputte
Check fuel filter in the shut off bowl. Then check the needle and seat in the fuel sediment bowl on the bottom of the carb.Also check the float when you pull off the sediment bowl.
Apr 15, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
371 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
