Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Blue lines We are getting random horizontal blue lines in the picture, mostly in 1080i, and when the picture we are watching is dark, like a night scene. This has just started. We've had the TV since 2005. Any thoughts?
  • 39 Answers
DB-IF IN FACT THE PIX IS GOOD ON OTHER INPUTS THEN YOU MAY HAVE A BAD FORMAT PCB.IF THE LINES ARE ALSO ON ALL OTHER INPUTS YOU PROBABLY HAVE A DETERIORATING POWER PC BD. PROBABLE COST OF REPAIR 350.00- 700.00.JOE TV
Posted on Dec 12, 2007
Horizontal blue lines
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 05, 2014 | Sharp AQUOS 52" Flat-Panel LCD HDTV
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
Dark and light horizontal lines in picture. What to do?
red, green and blue bowed lines? could be retrace lines. check CRT(picture tube) or try adjusting G2 voltage. What brand and model?
Dec 28, 2009 | Televison & Video
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Have a 42" flat screen; the picture goes blank after two minutes each time after turning it on.
Hello
I have the horizontal line problem but I do get that random black screen issue. I called xbox support and they told me to change the settiong to 1080i (found under console settings/Display), so far I haven't had any issues.I don't have the horizontal line problem but I do get that random black screen issue. I called xbox support and they told me to change the settiong to 1080i (found under console settings/Display), so far I haven't had any issues.
And my problem is also resolved and its working fine.
Assistance by phone seven days a week.
1800 555 741
Thnaks & Regards
Apr 04, 2009 | Samsung SP42P2S Television
KDF-55XS955 Blue lines
problem is going to defective optical engine $920.00 for repair sounds about right if not cheap. the parts cost is most of that price. check sony website or call and see if they will pay the repair cost for you.
Mar 10, 2008 | Televison & Video
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Random, intermittant blue lines
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
