Question about TruTech TT320
I have a trutech TT-320 and the little blue lights stays on but the unit does not respond to any buttons. Also, the drawer doesn't open.
  • Anonymous May 11, 2009
    Little blue ligh stays on but doesn't open
    Problem Solver:
  • 4 Answers
You will need to take your brand to a techn to change the main motor of the drawer. the motor is not working.
Posted on May 13, 2009
  • Robert H Danelson
    Robert H Danelson Jan 10, 2011
    You must first click on the "STOP" button on your remote control. Then go to the front of the DVD player and push the bottom right button (standby/on) then, click on the button that says
    "power" on the remote. A pause between pressing buttons is needed (to discharge any residual electrons in the unit). If you can't get the draw to open then you may have a disc in the player stuck. This is rare as in order for this to happen one would have to insert the disc under the tray instead of on it as is the correct method of inserting a disc. If you find a disc is stuck inside and under the tray. Disconnect the power cord. turn over the player and look for the slot that has letters stamped into the casing bottom. They say to;push to the left (direction of arrow), then insert a pin and push it to the left. This will manually push the tray out. If in the event a disc is still stuck inside either take it to a repair shop or if you are handy, open up the player removing the phillips head screws around the outside. Don't forget the 2 on the bottom front. Good Luck as this company is out of business today.
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Power cord replacement
Yes. But you can buy one from an electronics shop.
Aug 20, 2013 | Computers & Internet
When I try to power up my acer aspire M1201 the power button isn't responding
Check to make sure that power is reaching the power supply of your unit. If it is and still does not work, then the issue is with the supply that needs replacement. Common malady.
Jun 20, 2017 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Hi, I need a pioneer dvl-909 service manual that tells how to replace the loading belt. Thanks, Bill
Try to see if the drawers are blocked by something either inside or outside of the case.
Mar 17, 2012 | Pioneer DVL-909 DVD Player
Where is the pin hole to manual eject a cd. Its not under the player isit inside?
The TT 320 does not have a pinhole, it has a slot. Push a small stick thru the slot under the unit and slide it across the actuator switch.
Sep 10, 2011 | TruTech TT320
I recently acquired a used Dell Optiplex 320 desktop computer. When I lay the computer flat, the dvd drawer will open and function. When I stand the computer upright, the dvd drawer will not open. I am...
Sounds like there's something stuck inside the DVD drawer that blocks the drawer from opening if it's not its side. Try turning it over onto the other side, just for a minute, and see if it opens. If it does, there's something blocking the drawer. If it doesn't, you'll probably need a new drive, as that one's literally worn out...which I've only seen twice.
Jul 04, 2011 | Dell Drive for Dell OptiPlex 320...
The DVD drawer will not open on the model TT 320
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | TruTech TT320
Trutech TT320
"Hide" the remote and try to operate the unit using the front panel controls. Does this work? Then the problem is the remote...accordianman
Feb 18, 2008 | TruTech TT320
Trutech tt320
my video stoped and the door will not open
this is the second this is happening to
please help me open door
Jan 10, 2008 | TruTech TT320
T600D -- door won't open, but functions well!
mine does the same thing and its only about 4 mnths old
Nov 15, 2007 | TruTech TT320
TruTech TT320 Logo
565 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
