Question about Cannon i70 Printer
Canon i70 print head does not move to the middle
The printhead is stuck on the right and won't move to the middle, and thus won't print.  Should I try and force it back?  The grean and orange lights are blinking alternately.
Thanks and regards,
Ursula     [email protected]
  • 8 more comments
  • DeeUSAMD Feb 08, 2008
    I have the same problem, My print head is stuck to the right and will not move, and my warranty has expired. If any one has the code, I sure could use it.
    Thanks
  • arlnew Jul 10, 2008
    THE PRINTER LIGHT SWITCHES FROM GREEN TO AMBER, BUT
    NOTHING IS ON DECK FOR PRINTING RIGHT NOW. HOW DO I
    FIX THIS:? I ALREADY TURNED IT OFF AND ON SEVERAL TIMES;
    ALREADY PUSHED THE AMBER BUTTON TO TRY TO CLEAR IT.
  • rObje Sep 30, 2008
    My printer has the same problems as discribed. How to unlock???
  • Anonymous Dec 03, 2008
    I am having the same problem right now. Flashes amber seven times...problem with the printer head. But it is stuck to the right. I did the hold the resume button and then hit the on button....hit the resume button twice and let go. Then I get a steady amber light and it won't go off without disconnecting the power. So what's up with that.
  • Anonymous Dec 31, 2008
    I have the same problem too. Is there anyone who can give better answer? The solution given doesn't solve the problem at all...
  • Anonymous Mar 05, 2009
    I have exactly the same problem. It happened between printings. I tried forcing the print head out, but couldn't. I also tried to lift the top silver flap, but am afraid to break it.
  • Anonymous Apr 02, 2009
    I have the same exact problem and I e-mailed tech support. They mailed me back this response:
    Thank you for writing to Canon technical support. We value you as a
    Canon customer and appreciate the opportunity to assist you. We
    sincerely regret your i70 printer is not respond properly, and the light
    continues to flash orange and green.
    When the Power light alternates between orange and green, the printer
    was not able to initialize successfully because of a hardware error.
    For troubleshooting purposes, please check and confirm the following:
    1. Power the printer on.
    2. Open the cover. (The print head will move to the center from
    the right.)
    3. Press and hold the Resume/Cancel button for more than three seconds.
    (The
    print head will move to the right a little.)
    4. Hold and lift the print head lock lever button. It is a silver piece
    that lifts up to release the print head.
    5. Lower the print head lock lever to lock the print head in place.
    6. Close the print head cover.
    7. Isolate the printer by powering off and disconnecting it from the
    computer.
    8. Check carefully for any objects or other material that may be inside
    the printer or sheet feeder.
    9. After waiting about thirty seconds, plug the printer in, power on
    and see whether the printer initializes properly with a steady green
    POWER light.
    If the issue continues, service regrettably appears necessary.
    The only problem is that when the power is turned off then on the print head does not center itself and I still get no response at all.
  • akbizou Apr 23, 2009
    I have the same problem right know.. The head stuck on the right side, won't move to the center. Is it the sign of Death of i70?
  • Lin Epp
    Lin Epp Dec 03, 2013
    I am having this problem. What do I do?
  • Anonymous Mar 28, 2014
    They have come up right in the middle of my desktop and I want them back on the side where they began. I tried to hold down the mouse ...left side and move but no deal
THERE IS A CODE THAT UNLOCKS THE HEAD. IT MAY BE THE SAME AS THE I80 PRINTER. DO NOT FORCE HEAD. THE CODE IS PUNCHED IN BY THE FEED BUTTON AT THE TOP. I WILL TRY TO FIND THE CODE AND REPOST.
Posted on Oct 17, 2007
  • Lin Epp
    What is the code and how do I use the code?
SOURCE:
I need to extract the printhead from a Canon MP540 printer in order to install a new one. I have just received an incomplete answer from FIXYA. When I turn on the printer and raise the cover, the...
The print head is not designed to be moved manually and damage may occur if you try to do so forcefully.
To center the print head to replace ink tanks and to replace/remove print head you should do the following:
1. Make sure power is turned on and open the Paper Output Tray gently. 2. Lift the scanning unit (cover) until it stops. Lift with document cover closed. The print head holder should move to the replacement position (center).
Do not force print head holder to move nor touch it while it's moving. These parts are very delicate and generally are made mostly of plastic.
IMPORTANT If the Scanning Unit (Cover) is left open for more than 10 minutes, the Print Head Holder moves to the right. In this case, close and reopen the Scanning Unit (Cover).
May 04, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Hello, My Canon MP830 suddenly shut off when I told it to print a sheet. It will not turn on, and the print head is stuck to the right, and I can't move it. I left it unplugged for several days, but still...
When the carriage is stuck on the right there's not much you can do, When the printhead goes bad it keeps your printer from powering up. You need to either remove the printhead, or unplug the light color ribbon cables from the circuit board on the right side of the machine inorder to power up, and then change the printhead. QY6-0061-000 around $60.00
Sep 30, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon i70 bubble jet printer : print head is stuck all the way to the right, will not center, green/amber light alternating continually. Help ?!
You Canon printer seems to have RETIRED when it does that. It is a common canon prblem and that is why the smaller canon printers are referred to as DISPOSABLE printers. The motherboard of the printer has got a problem on it and would cost more that the price of a new printer to have fixed.
Jul 06, 2009 | Cannon i70 Printer
The print head won't move stucked in the middle
Try uplugging the power cord, wait 2 minutes, the plug it back in, the printer head should return to its home position. Let me know if this helps.
Mar 28, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Feb 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Print Head
After opening the purple cover, the printer head will move to the center. There should be a gray tab on the left side of the forward facing opening (about the middle of lower cartridge). Gently push printer head to the right (1/4 to 1/2 inch) and a gray slanted tab will appear from behind housing. lift this tab and a metal lock will pop up. Tilt lock back and the printer head should be lying loose in its cradle.
Apr 11, 2008 | Canon PIXMA iP90 InkJet Printer
Canon iP90 Printer Problem
take printhead out and put cleaner or turps on gauzes, dab off with paper towel, reassemble and run clean programme - this worked for me and from no black output I ended up with full function printer
Jan 02, 2008 | Office Equipment & Supplies
2,046 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Ekse
Clive
Clive
Inky Fingers
Inky Fingers
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
