Question about General Electric DHDSR46EGWW Dryer
START SWITCH HUMS BUT THE DRUM DOES NOT ROTATE
  • Judy Arnett May 18, 2009
    Front loader Frigidare AE06000ES2 just hums when turned on. I opened door, turned drum while holding in door button. Works like a champ.
  • 478 Answers
Try turning the drum while holding down the start button the belt could be twisted
Posted on May 10, 2009
    Problem Solver:
  • 5 Answers
Rotate the drum by hand while depressing the door button and running dryer. Mine did the same thing and this worked.
Posted on May 18, 2009
  • 1,305 Answers
Sounds like the drive belt (which is wrapped around the drum on the outside) has come loose, off the pulley or broken...
Pull the front cover off the dryer and look below the drum where the motor is... you should be able to see if the belt is broken or loose.
Let me know if you need help figuring out how to change it.
KEN
5 Suggested Answers
  • 91 Answers
SOURCE: kenmore dryer hums but will not rotate
PRETTY OBVIOUS REPL/ MOTOR
Posted on Jan 03, 2009
  • 10 Answers
SOURCE: drum does not rotate and selecton knob hums
If the motor hums when trying to start it could be a bad motor. Sometimes, but not all, caused by a vent leak and the dryer will **** in the vent air and it's lint and blanket the motor not letting it breath. If it's old and it is the motor probably cheaper to buy a new one.
Posted on Jun 30, 2009
localwonder
  • 6784 Answers
SOURCE: Dryer humms but does not turn unless I rotate drum when turned on
HI. This is a damaged sator assembly in the motor casing. the cooper windings are damaged. this motor will need to be replaced asap, if possible.
Posted on Oct 19, 2009
dmftrucker
  • 1922 Answers
SOURCE: my hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Posted on Oct 24, 2009
When I push the start button, the dryer does not come on, but it just hums.
Check to see if you can rotate the drum. if you cant then you need to check the blower wheel. If you can then hold the door switch in and start the dryer. if it starts to hum rotate the drum while holding the door switch in. if it runs on it own after you rotate it then you need a new motor
Jul 12, 2011 | Kenmore 600 6963 Electric Dryer
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
Our Maytag gas dryer drum doesn't turn. Replaced belt. Heats up but drum isn't turning
There are three possible reasons why the drum doesn't turn.
  1. Broken belt. You replaced the so in this case it's not.
  2. Door switch. The dryer will not operate if teh door switch is defective. It is inside the drier main housing near the door frame. You need to raise or open the top or front of the dryer to reach the switch. Replace if defective.
  3. Motor. If the motor hums when the start button is pressed, the motor maybe burned-out. Check the dryer motor:
  • Check the blower fan housing for obstruction and manually turn the motor shaft.
  • If the motor is very stiff or cannot be turned manually, you need to replace the motor.
  • If the motor rotate freely, run the motor without the belt. If it runs fine, there maybe problem with the idler pulley or the clothes drum.
  • Rotate the drum by hand. If it is difficult to rotate it, correct any problem with the rollers or pulley. Reassemble the dryer and try it again.
  • If the motor hums but does not run on it's own even without the belt,but can be turned freely by hand, you need to replace the motor start capacitor or the motor itself.
Sep 25, 2009 | Maytag Dryers
My dryer has power but the drum will not turn
Belt, Motor, motor start capacitor or Door switch. you going to have to open the back cover off and see what is taking place. check belt making sure good and tight, idler pulley may be worn also. If motor only making a hums sound when you press start it may be burnt out. you can check if the motor is good or bad by removing the belt and manually rotate the shaft motor pulley, if the motor is stiff and impossible to rotate manually, it also a sign the motor burnt out. if the motor turn and run freely without the belt, the problems maybe with the pulley or the drum, try to rotate the drum and making sure it rotate freely using very little effort. if door switch faulty, the unit will not work.
Sep 01, 2009 | Maytag Dryers
THE DRYER WILL HEAT BUT THE DRUM WILL NOT TURN. I HAVE CHECKED THE BELT AND IT IS OK. NOW WHAT
Hello. I can help you. Since the belt is ok there are only two other possible problems:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Jul 16, 2009 | Dryers
Dryer not turning. belt is good
  • Remove the belt.
Dec 17, 2008 | Whirlpool Dryers
General Electric DHDSR46EGWW Dryer Logo
361 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Harry Roberts
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
