Question about Frigidaire FEF366 Electric Kitchen Range
Oven preheat frigidaire FEF74ASE takes too long to preheat 10-15 min. what can i do to fix
  • 3 more comments
  • atellez Oct 12, 2007
    oven is 3-5 years old. FEFL74ASE
  • atellez Oct 14, 2007
    yes the preheat is 10-15 min. and i was hoping that there might be a way to shorten it. i feel that it is a bit long. i know that some ovens take less time as short as 3 1/2 mins. so i suppose i deal w/ it or buy a different stove. thanks for your input.
  • jenesis Jan 03, 2008
    I have a frigidaire gas range. As of 3 weeks ago it is taking an extreme amount of time to preheat. I am talking on the range of 60-90 minutes. This is up from 15-25 minutes before. It is 3 years old and there are only two adults in my house that I cook for.
  • Carlban Mar 16, 2008
    I also have a Frigidaire model# GLGF377AQC .. and it takes up to over 60 minutes to preheat..wonder if theres any solution?
  • Kurt_S Apr 15, 2008
    We also have a problem with oven preheating on a Kenmore gas oven (I don't know the model, maybe from the 1990s, although it looks new). It takes about 15 minutes for the preheat buzzer to go off, but the oven can be 20-30 degrees less than the preheat temp was set. It may take 30 more minutes more to get up to the "correct" temp (we bought a thermometer to test this). Understandably, things take much, much longer to cook than they should. A service guy said "that's just the way some of these are" and increased the temperature setting, which hasn't helped. Is it time to buy a new one? If anyone can help, thanks.
    Kurt
  • 473 Answers
A few questions first.  How old is your oven?  What is the entire model # that is on the sticker on the oven.  Model # should be somewhere behind the bottom drawer.
Posted on Oct 11, 2007
  • Craig Shelton
    Craig Shelton Oct 12, 2007
    Are you saying that the preheat is 10 -15 min.?  If so that is really about average time.  I would look at the door gasket and make sure it looks ok so your not loosing any heat.  Let me know if this helps or I misunderstood your problem.
SOURCE:
What is an F50 code on frigidaire gas range? Oven preheated, placed food in oven. 2 mins later it beeped 3 or 4 times and displayed F50.
The F50 code appears to indicate that the oven relay board can't get the status of the switches (door closed, motor door lock). Try unplugging the range to reset the control board. Next check the wiring harness. If there is nothing wrong with the wiring, then the oven relay board may be faulty.
Please add a comment with the model of the Frigidaire range if you would like a parts diagram and other information. I hope this helps.
Jun 03, 2018 | Frigidaire Kitchen Ranges
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
My oven bakes, but it takes 30 minutes to preheat
Hi friend, thank you for your post!
I know from your post that your Frigidaire oven is working but the preheat takes 30 minutes. This does sound like lengthy amount of time for preheat to be completed. From what you are describing it could be an issue with the panel, element, or thermostat. Since it could be anyone of these underlying issues I would recommend having a professional come out to diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts. -Matt
Aug 06, 2014 | Frigidaire 30 in. Electric Gallery Series...
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
My Jenn Air JGS8850 takes over 10 minutes to preheat to, say, 400*. Is this normal?
In a word...Yes !
10 min. is actually a really great preheat time. I have many customers who would kill for that kind of preheat, most are between 15-20 minutes minimum to 350 degrees celcius, especially with the introduction of hidden bake elements in the last 10-15 years.
Hope that is helpful,
Good Luck :)
Oct 22, 2009 | Jenn-Air JGS8850 Gas Kitchen Range
Whole wheat cycle no longer works!
Are you taking into account the preheating for whole wheat cycle? The machine preheats for 30 minutes before normal cycles start - only on whole wheat setting.
Oct 10, 2009 | Breadman TR875 Bread Maker
Takes 20 minutes to preheat.
The unit seems to be working ok....usually the temp probe will reach temp in 5 minutes and it will beep....i sugg for cust to let sit for 15-20 mins for precise cooking.
Jun 11, 2009 | Kitchen Ranges
Frigidaire FEF366 Electric Kitchen Range Logo
1,126 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
