Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Double images on my tv. My multi point wont change
Multipoint
  • Philips Master
  • 3,459 Answers
Classic convergence problem. You can get a complete repair kit from www.TvRepairKits.com
Posted on May 14, 2009
Sony KLV-32S550A LCD TV double image.How to fix
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 21, 2016 | Sony KLV-32S550A 32 inch Multi-System LCD...
Good afternoon, how can fix the double image in Sony KLV-32EX330 Please help me to learn to fix my tv, thanks for the answer,
double imaging or ghosting is normally a result of faulty tv antenna,cable or connections
check that the antenna is pointing in the direction of the transmitter or tower 9 change from strong winds etc)
raise it higher from the roof line to prevent signal reflection
ensure that the antenna in use is correct for the station signals
call in an antenna expert to check the antenna and signal strength
Jul 20, 2016 | Sony Televison & Video
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Double image on screen on 52"projection screen
You'll need to do a "Convergence" procedure on your television, which re-trains the
three color guns to focus on a single point, correcting the double-image problem.
This link points to a how-to video & also how-to instructions:
http://www.fixya.com/support/t7212007-colors_separated_double_vision
The procedure is actually in the instruction manual for your TV, and at least one mfr recommends that
this procedure be performed on the TV once each month.
Cost to you: $zero
Jan 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My phillips 60 in projection tv has color distortion and the multipoint converge wont let me adjust the cross hairs
Hi..... well if is a LCD Rear projection Tv is a issue with one of the color filters, and you will need to change at least the optical block or the light engine system, I always buy them from www.discount-merchant.com
If TV is DLP it might be a issue with the color wheel, you might be able to hear a buzzing sound.
Jun 27, 2009 | Philips 60PW9363 60" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
Philips 60pw9363 double image
You have bad convergence ICs. Replacing them with any possible bad resistors will fix the problem. They are hooked to the largest heatsinks inside the tv, like stk392-120 or simmilar ICs.
Dec 06, 2008 | Philips 55PW9363 55" Rear Projection...
Double image, blue and yellow images
convergence ic are going or have loose connection in the convergence amp ic area.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Hitachi 43FDX01B TV
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
