Question about Jenn-Air JGR8850 Gas Kitchen Range
Installing downdraft venting
Is it ok to run vent down 1foot to go under floor joist and then back up to meet existing vent from old jenn-air i am replacing. my run is only 8 ft long to outside wall thank you much richard
  • 1,305 Answers
Richard, you should be ok, you may want to check it periodically to make sure that grease isn't building up in the low spot... You are adding a couple of bends, but it should still draw well.
Posted on May 10, 2009
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air downdraft
They should be pretty close to the same, if not, it would would very inexpensive and easy to modify or adapt the new one. Mostly the vent piping would have to be modified. Like I said though, you shouldnt have a problem at all.
Nov 16, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Downdraft fan not pulling test card down
whats you model number as does it sound like fan is running and what do you mean by not pulling test card down did you just install it or had it for awhile i will try to help
Jan 02, 2008 | Jenn-Air JED8430 Electric Cooktop
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JGR8850 Gas Kitchen Range Logo
322 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
