Question about Kitchen Appliances - Others
Broken leg - need replacements
I have a GE Automatic Fry Pan Model # S2F which has been providing outstanding service for 40 + years. One of the bake-lite legs has broken making it difficult to use. Can you advise as to where I may obtain new legs or a recommended repair for this problem.
  • dahanson May 10, 2009
    Yes I have the pieces to the broken leg.  I had previously tried to epoxy them together, however the epoxy did not do the job.
  • Samuel Charles Spriggs May 11, 2010
    Do you still have all the pieces of the leg and how many pieces are there?
    President:
  • 1,304 Answers
Bake lite is very hard to repair
but i ahve made this very repair using a varied amount of things with varied success
depending on where it broke yo may want to try gorilla glue
if clost to the bottom get som jb weld from your harware store this will do it it may not be prtty but it will work
Posted on Oct 08, 2009
My toastess fry pan leg broke how do I replace it all 4 joined with 1 screw
you will need to get a complete new stand unit
or there is a product on the market that has a liquid that is set by ultra violet light
you could get that and give it a try
Apr 17, 2017 | Toastess Kitchen Appliances - Others
I need to replace my power cord for my Hoover stainless steel fry pan.
Assuming you have already checked with the manufacturer's website or phone contact, I would suggest you check out ereplacements<dot>com. I have found almost all of the so-called 'orphan' appliance parts I have needed with them. If they don't have this item, do a web search on 'Hoover fry pan cord replacement' and see what you get. Something on a search like this has always gotten me what I've been unable to find otherwise. Good fishing.
Sep 27, 2015 | Kitchen Appliances - Others
Do you have 2010 diesel holden cruz automatic repair and maintenance manual
one automatic transmission coming up in a search with the 2010 holden cruize is the
australian commodore 4L60E deep pan filter
does that sound like the right one
that transmission gets a service once a year or 40 ,000 km.. dexron 3
they are not worth rebuilding if they have failed
the 4L60E repair manual is free online
Mar 22, 2015 | Vehicle Parts & Accessories
Hoover electric fry pan cord JPR 1104. E-mail arlie.t@hotmail.com.Do you have one or do you put me on a list? Thank you.
I stumbled on this website by accident when I was trying to find a heat control for my Hoover fry pans. I own three. One is a model 8611 Fondue/Minnie Fry pan. It uses a "UniProbe" JPR 904. The control is rated 1650 watts, the pan is rated 800 watts. Your 8600 is a larger full sized pan. I do not own one of these pans to check the wattage. Read the wattage on the back of your old control as well as the bottom center of the pan itself. My research has not turned up any replacement for this part design. I never saw a competitor use this Uniprobe. I own a B3039 Broiler Lid full sized fry pan (Vintage about 1975). The pan is rated at 1200 watts with the control rated at 1500 watts. Yours is most likely a similar rating. The control is a no. 9906 or a78T. Neither, the UniProbe or the newer type is available from Hoover. The UniProbe was used in the 1960's and early 70's. It had three female connections. The outer two bring the wall current to the imbedded heating element in the pan. The center connection transfers heat from the pan to the temperature control and causes it to go on and off making it automatic. The later type control has the two outer female connections and brings in the power. The center connection was changed to the common male probe and transfers heat to the control to make it automatic. After a serious hunt for replacements I located the Presto control 0690005 rated at 1500 watts (just like the Hoover). Presto says their parts only work with Presto appliances. It works with Hoover for me, so I am happy. I bought the Presto griddle to test the probe compatibility and obtain the needed probe. I did find a company (by doing a "Bing" search) that claims they can bore the pan to accept the later type, probe (www.kieferappliance.com). Their approach sounds promising but if you decide to try this approach, do your own research of this company. If I understand your question correctly: I am not a parts dealer. I found a part that is serviceable for this long out of production "GEM" from Hoover. I am giving owners of these pans a way to continue using their pan as I did with mine. The downside seems to be that my simple fix for one style cord won't work for you. However, those that have one of the later models can continue to enjoy the uniqueness of these fine frying pans by trying the Presto control. CAUTION: Do not just start trying other parts to replace a missing part. It might be a dangerous experiment. Hope this clears up any misunderstandings. (As a side note: The main reason these controls fail is rough use of the cord going into the control itself. Too much pressure where the cord enters the control and the fine strands of wire will eventually break causing no electricity to get to the appliance. This will happen with any toaster or coffee maker or lamp cord or electric drill etc. These may be able to be repaired but it is not easy and is very time consuming.
Nov 24, 2014 | Kitchen Appliances - Others
I need a new "leg" for my society electric fry pan
You don't need anything unless the frying pan doesn't work because of the leg.
what you can do is just put an object in place of the leg it works out cheaper too
Oct 21, 2013 | Society / Regal Ware Society Regal Ware...
T Fal fry expert manual
My friend give a Fry expert but haven't manual. I don't know how long to fry chicken leg or fried. Could you provide to me?
Oct 25, 2010 | Vacuums
Several years ago we bought your electric fry pan from QVC..It has been my favorite kitchen item, but recently the electric control that plugs into the pan has overheated and melted on one side...Any...
Try contacting the manufacture to see if you can order one from them or someplace else. The manufacture's name and model number ought to be on the bottom of the pan. Use the Internet to get their contact information. Please rate this advice.
Aug 21, 2009 | Kitchen Appliances - Others
Toastmaster replacement cord for electric fry pan.Cord model 1202 . Fry pan, stainless, model # P803
I got the phone # 4 Toastmaster on line, called them. They said the pan was 2 old 2 have the plug in stock any more. I called a local repair man who said he could put a new cord in the present "plug". Has to solder & re-wire temp. plug.
Thank u for asking, u have a good source for people 2 go 2 4 lots of issues--very effective. I'm glad 2 know u're there!
Jul 28, 2009 | Toastmaster Kitchen Appliances - Others
Need replacement broken Leg
1-800-323-9519. thats the number for rival customer service they might be able to hook you up
Mar 30, 2008 | Kitchen Ranges
Kitchen Appliances - Others Logo
390 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
