Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
G.E. (GSC3408K00WW) Hi ran dishwasher without water supply valve open, oops. Know it sprays water and after a minute and a half it kicks out the breaker in the apartment. I flipped it over and the motor shaft and pump shaft turn by hand. Any ideas what could be the problem other then operator error, LOL.
  • Samuel Charles Spriggs May 11, 2010
    When you say "now it sprays water" is this different from the way it operated before this unfortunate incident?
  • 188 Answers
SOURCE: usermanual for old ADMIRAL dishwasher model number BDUR 41400
right. first of all there are usually three settings one is intence 2 is normal and three is pans. or the other way round. cannot remember. but put nothing in and turn it on by closing the door. turning the knob and pressing the start button when selection is made if no button to start it just select a program and see which one lasts the longest thats the pan one. use dishwasher tables either in the little basket hanging in there or in the door there is a slide thing. put tablet in there and fiddle till it stays shut. then close the door. after loading with stuff. at the bottom will be an unscrewable white knob put some dishwasher salts in there every few months. it keeps the water soft. there is also a filter in the bottom you can lift out to clean a round thing within a mesh grid. that must be reg checked for bits of dinner and stuff. try and get the bets off first. dont put beans and things left on plates and pans in cloggs up. try contacting supplyer for instruction manual. if you cannot thats all you need to know really. hope that helps. liz
Posted on Mar 28, 2009
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
  • 111 Answers
SOURCE: Dishwasher will not fill up with water
did you chek the level micro switch thats in serie with the intlet valve
Posted on Jun 18, 2009
  • 227 Answers
SOURCE: I've got a GE dishwasher, a GSD2800. It's giving
If this is a new install where there was no dishwasher before. Or if your garbage disposal has been replaced. Then the plug in the garbage disposal inlet for the dishwasher drain may still be in place. You will have to disconnect the dishwasher drain and see if the inlet is clear. If not the garbage disposal will have to be removed, the plug punched out and then reinstalled. Good Luck!
Posted on Jul 24, 2009
  • 163 Answers
SOURCE: GE nautilus wont spray water.
if you ran it for a long time you will need a new pump water keeps it cool and from sezing up
Posted on Jul 26, 2009
Dirty Dishes
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Sep 28, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Kitchenaid dishwasher - small pieces of food are left on otherwise clean dishes. Water level comes to about 1 inch below heater coil. I ran it without dishes (or soap) and added about a quart of water so...
hello
contact the Help line
Call 1-800-334-6889
Major Appliances:
8 am - 8 pm EST (Mon - Fri)
Countertop Appliances:
10 am - 5 pm EST (Sat)
KitchenAid Experience® Store
1-888-886-8318
Thank You
Sep 11, 2008 | Dishwashers
Dishwasher doesn't fill with water!
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 28, 2010 | KitchenAid KUDI24SE Built-in Dishwasher
No water in the dishwasher Bosch SHX43M02-48. We turned of the water and forgot to turn it back on and ran the dishwasher. Now the it will not let water in?
Hi, By the information you've supplied, I'd guess you burnt out the coil in the water/fill valve by running it without a water supply to the valve. Are there any other unusual symptom's or error codes ? i.e. drain pump running none stop ? Can you put water into the tub manually and run a rinse cycle without issue ? In any event the valve is pretty inexpensive, usually about $30 or so. The part # 425458 works on all bosch, thermador, gaggenau, and siemens dishwasher built since the early to mid 90's up to present day. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck. macmarkus :)
Mar 05, 2010 | Bosch Dishwashers
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
No water spraying and there is water going to the dishwasher
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jul 13, 2009 | Dishwashers
Will not clean dishes on the upper rack
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
My dishwasher sounds like its working but when i open it nothing
1. No water
2. Not enough water
3. Clogged spay arms
May 30, 2009 | Bauknecht 24 in. GSX7551 Built-in...
How to take the upper and lower spinner off.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Dec 01, 2008 | Maytag MDB7100AWB Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
454 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
