Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Can i up grade my processer on my dell dimension 5150 desktop computer and if so how big of a processer can i upgrade and is it easy to install.
    Sergeant:
    Champion:
  • 225 Answers
Good morning! Yes, you can upgrade the processor of your computer but it will depend on the compatibility & support criteria of your computer motherboard, I suggest to check/review the product/operations manual of your computer motherboard which will inform us the details of specification requirements of processor that your computer motherboard will support & compatible with. Installation of processor is easy but with caution just follow the steps procedures written on its enclosed product manual, then make sure to install it with a good CPU FAN that will control its heat temperature. best regards.
Posted on May 10, 2009
Dimension 5150 (DIM515MIN) PC Desktop: I want to know what kind of case a dell has. I'm p...
The Dimension 5150 has a BTX case, which is nearly impossible to upgrade. The motherboard is NOT interchangeable (with a few exceptions, but none of which are true upgrades).
If you have a PCI Express slot, you can upgrade the video card but do not get a card that requires an additional power cable directly from the power supply. This is because the stock power supply is very weak and doesn't have outputs for additional cards. If the card requires no additional power, you should be fine.
You can upgrade your processor with the P4 [Prescott] 5xx or 6xx Series Processors with HT. The 5150 does not support core 2 duo processors. Depending on what you currently have, this may or may not be worthwhile. Also note that higher power processors run at higher temps, which sometimes causes a noticeable increase in fan noise.
The hard drive is easily upgradeable. Just buy any standard sized SATA hard drive. Your computer case supports two drives, so you could keep your current drive and just add a second drive. Remember to buy a SATA cable with the new drive because new drives usually don't come with them.
Overall, if you're looking to get outstanding performance, get a new computer. BTX computers are not gaming computers. You'll end up dumping money into this thing just to get a lousy increase in performance.
May 18, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Recent upgrade of 320gb sata hard drive and additional 2gb of DDR2 400mhz memory.Installed and configured by dell to my dimension 5150 has not solved my problem of.CPU usage when on broadband of 70-80% and...
Have you tried to reformat or wipe out your computer? If not I would go ahead and do this with a clean installation of the OS. If it continues to act up , then you definitely have a hardware issue. Please post back after you do this or have done this already.
Feb 18, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150
This high end video card that you just upgrade to requires a high power supply , so this can really be a power supply issue so trying a high power supply will be a good thing to do...
Aug 17, 2009 | Computers & Internet
Dell dimension 5150 ethernet problem reloaded windows xp home from a windows xp entertainment os. apear fine but not receiving.
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Jul 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Geforce 8600GT gaming problem.
whats power supple do you have? i have a 8500gt and it needs at least a a 350 watt most of those dells have a 305 watt upgrade to a bigger supple hope this helps
Feb 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 - Options for upgrade
Usually motherboards corresponds to the Dell Number. You can change your motherboard alone from a local technician. However, that's strongly not recommended.
Jan 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
PNY memory
Hi
Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
Let me know if further help is needed.
Mike
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Change Motherboard For Dell Dimension 5150
If you replace with the same motherboard that's in already, that would be easiest for you.
But if you use a different one, you'll have to re-activate Windows, and download and install new device drivers.
Jan 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
173 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
