Question about Garden
I have montgomery ward riding mower and cant
I have montgomery ward riding mower and cant remember how to rehook itthe deck of my
  • Anonymous Mar 20, 2014
    Old Montgomery ward 6 1/8 power jointer run great needs a guard
    Problem Solver:
  • 14 Answers
Line up the deck where it needs to be, and lower the lever....the hanging links should come close to where they go, then use the pins (or whatever) to insert into the hanging levers....Leave the handle lowered, then hook the belt onto the engine pulley, then line it up with the pulley on the deck...you may have removed the belt guides, so put them back on...They help keep the belt from falling off.
Check your work to make sure things look right...You should be done.
Posted on May 10, 2009
Need belt diagram for montgomery wards 2000 elite riding mower
mtd signature 2000 elite Also, make sure you push in the clutch/brake in order to create enough slack to get the belt on....Good luck!
Aug 20, 2014 | Garden
I can't get the deck to ride/cut evenley on my montgomery wards yard tractor
check your blades,Needs to be leveled , Possible bent deck.
Jun 19, 2014 | Briggs & Stratton Garden
Riding mower won't start
clean all your battery connections from battery to starter and selonoid connections and ground cable also where it connects to frame
May 23, 2010 | Garden
Lawn Mower wont start
You need to obtain a manual for Briggs & Stratten engines. All the info you need will be in it. The most common cause for non starting in these engines is "Tight Tappets" Wether it's an OHV or the old "L" head engine, because they rev and work so hard, the valves seat themselves deeper into their seat which reduces the valve clearance. There is no adjustment on the older "L" engines, so you have to remove metal from either the valve stem, ot the lifter itself. I have in the past done this in situ with a point file, but it is a tedious job. Otherwise you must remove the head and take out the valves and grind the stems. A tricky task and probably should be done by a mechanic.
Apr 06, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Hi i have a montgomery wards riding mower 1990
I might know what the problem is, on those models there should be a ignition switch, or a killswitch under the seat of the mower. When the 2 people sat on it, it might have jarred or broke the switch. You might want to check it to see if thats your problem. I hope this might help.
Nov 02, 2009 | Garden
Have a power kraft 18.5hp with 46'' deck, need a
first you'll need a model number. look on the underside of the seat, or on the metal plate between the rear wheels for the model no. sticker. wards tractors were made by MTD. there will be two numbers plus the serial number, write 'em both down. then log on to www.milacalawn.com. in most cases, you'll be able to pull up an owner's manual for your tractor with one or the other model numbers
Aug 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The engine starts in when the choke is on (however a lot of smoke) and once I move the throttle, the engine shuts off. Any suggestions???
Sounds like possible the engine gaskets need to be replaced.. Sounds like head gasket may be bad and losing compression.. Had same problem on montgomery wards tractor few years ago. Had engine overhauled and now works good..
Jul 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
283 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
