Question about Telex SpinWise 7-824D (301689000) DVD±RW Burner
I need a manual!
My brother and i run an independant productin company and have recently purchased a duplicator but the individual who sold it to us did not give use the owner manual. iwas attemping to see if i can download one from the site. how do i obtain an owners or operational manual?
  • samq1962 Jan 27, 2009
    Telex SpinWise 7-824D DVD±RW Burner
    New Friend:
  • 3 Answers
Simply Google "Telex Spinwise Manual .pdf "
Posted on Feb 05, 2008
SOURCE:
I got a gift from my brother who lives in another city then I do and the gift he sent me I already have. So I would like to return it. How do I do that.
You will normally need the original receipt, a gift receipt, or the original order information. Contact your brother or the company that sold or manufactures the item.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jan 08, 2017 | Miscellaneous
I have a brother fax, model 525 DT. When you hit the number key for 7, it does not respond. In other words, that number does not appear in the window. As a result, the fax number is incomplete and fax...
Unfotunately you probably already know the solution here. The keypad needs to be replaced. There is a way to get into the pad and attempt to fix the individual key itself, but if you are here posting this, I'll simply assume that you don't have the technical skill required to fix that individual keypad.
If you purchased it recently, I would go to brother's website, find their support number and call them. It MAY still be under warranty. They can also advise you of any pricing and installation costs associated with replacing the keypad. I have over 20 years experience on office equipment, and I HIGHLY stand behind Brother and their services. Their support is very friendly and will help you... ;)
www.brother-usa.com
Sep 03, 2011 | Brother Office Equipment & Supplies
Actually the warranty is out so what i supposed to do
We all know that the warranty cards are very important when we purchase some items that have a motor or have a warranty..
I think the best you can do is to go to the store where you purchase your items and ask for a duplicate of your warranty..Because as far as i know they have a duplicate that they forwarded to their company,for the company record..
If you cannot asked for that duplicate you show also your purchased receipt if they will honor it if not then the best you can do is to go to directly to the service center for the service of your items..
Jun 28, 2011 | Garden
Where can i get a manual for the kanguru cd duplicator
How old is the duplicator? The company has two different manuals listed here: http://support.kanguru.com/index.php?action=file_library&folder=19 . The pdf version is for their current models: http://support.kanguru.com/download.php?FLIB=1&id=40 . A zip file contains the manuals for duplicators sold before 2009: http://support.kanguru.com/download.php?FLIB=1&id=42 . I suggest you try the manual for the older models first; the current models on the kanguru site have models numbers like U2-DVDDUPE-S1 .
I hope this helps.
Apr 25, 2011 | Kanguru (U2-DVDDUPE-D118) Burner
I need new needles and bobbins how do I find right ones
You can use Schmetz needles and the bobbins are Class A or Class 15. Both can be found where sewing notions are sold.
You choose the needle size according to the type of fabric you are sewing. This should be in the manual.
If you need a manual, you can download from the Brother website.
Apr 23, 2010 | Brother XL-3500
The bobbin will tread at all! no fabric is caught-up. motor run but not threading.
If you need a manual to see if everything is set up as it should be for winding a bobbin or any other feature of the machine, you can view or download here - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=CS80
If you are still have a problem, the bobbin winder may be broken.
You can have it repaired or purchase an auxiliary bobbin winder for a lot less money - SideWinder Bobbin Winder where sewing notions are sold.
Mar 20, 2010 | Brother CS-80
Need help in using the grace sure stitch regulator of quilting
I am having irregular stitches on the forward/backward motion. I am using a Janome 16000 P on a Gracie II frame. (I purchased this as a used productin a private sale) Do I need a darning plate to effectively use the Sure Stitch regulator in a free motion mode or with a template?
Mar 04, 2010 | Janome Sewing Machines
I have thousands of duplicate music files on my computers for itunes. They make a mess of my library and take up hard drive space. How can I erase the duplicates without having to manually delete each...
If there are some duplicate songs in iTunes, you may listen to the same song for more than once. This is a bit annoying sometimes. In order to resolve how to delete duplicates in iTunes, you can read the contents shown below.
1. Run iTunes on computer and ensure it is the latest version. Click on the "Music" panel in the left sidebar. And then you need to tap the "View" button in the toolbar and then choose the option of "Show Duplicate Items" to click on.
2. The duplicate songs will shown in the right part of the interface. Choose the duplicate item that you want to remove from iTunes and right-click on it. After that, click on the "Delete" button in the menu.
3. Click on "Done" button after you delete the duplicate song.
You need to repeat the same deleting step until you remove all the duplicate songs. After you deal with how to delete duplicates in iTunes completely, you can listen to iTunes songs happily and at ease. There is no need for you to worry about listening to the same songs once and once again.
For more details, check: How to Delete Duplicate Songs in iTunes
how-to-delete-duplicate-songs-in-itunes-show-duplicate-songs-3-gwujvob1wsqcwi5j4bnkubbk-3-0.jpg
Sep 12, 2009 | Apple iTunes
Brother MFC-8840D ghost image
most likely you have a bad drum. it can also be the fuser.
what is the distance between the first word and the duplicate that follows it.
Mar 31, 2009 | Brother MFC-8840D All-In-One Laser Printer
Telex SpinWise 7-824D (301689000) DVD±RW Burner Logo
274 people viewed this question
Top Telex Computers & Internet Experts
Damen Wong
Damen Wong
ray gallant
ray gallant
Tom Chichester
Are you a Telex Computer and Internet Expert? Answer questions, earn points and help others
