Question about Olympus RM-1 Remote Control
Rm-1 Olympus remote. I have 2 of them and can not get them to work with my Olympus E510. New Batteries, tried to set frequency. No luck. Any advise?
    President:
  • 919 Answers
Starting on page 45 of the user manual explains how to use your RM-1 remote control. You have to set up the camera in remote control mode in order to fire the RM-1.
Posted on May 11, 2009
RM-VZ320 won't even turn on my player, help?
depending on age you might have to take apart not hard and clean the key pad where they make contack with bard with pencial erraasor or rubbing alcohol and a cotton swab to clean contacts good luck
May 03, 2014 | Sony RM-VZ320 Remote Control
My remote control does not work anymore for my JVC MXJ30 Stereo. How can I determine if I need to buy a new remote. The stereo works when I turn it on manually. However the CD player has stopped working....
There are a couple of things going on here.
The CD issue is, uh, common. They die. CD-cleaners are dubious at best.
http://www.repairfaq.org/sam/cdfaq.htm
For the remote, try this advice:
http://remotes.com/remotes/servlet/rs?=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the
unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
eBay has some RM SMXJ30J remotes cheap. This one will set you back $11.50 delivered.
http://cgi.ebay.com/JVC-RM-SMXJ30J-REMOTE-CONTROL-/120717037068?pt=LH_DefaultDomain_0&hash=item1c1b4bce0c
May 07, 2011 | JVC MX-J30 CD Shelf System
Cant find manual - need to set up from scratch on E500
Try this link:
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/esystem/qsg_e500_en.pdf
Nov 20, 2009 | Olympus RM-1 Remote Control
REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
May 27, 2009 | JVC LT-26X575 26 in. LCD HDTV
Will Olympus RM-2 remote work with this camera
Yes the RM-2 is an accessory that can be used with this camera.
Apr 15, 2009 | Olympus Evolt E-510 Digital Camera
Remote model [AV SYSTEM 3] RM-SS880 not working :
Need remote code for this home theater. I have Sony RM-V210T universal remote but cannot set it up to work with dav s880. Only PLAY button is working...
Mar 19, 2009 | Sony (RM-SS880) Remote Control
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Remotes won't work
Sounds like a frequency issue. A remote work like the radio in your where each station is on a different frequency. Some signal is interfering with you frequency (390Mhz) You could try another brand external receiver with new remotes or with that old of an operator you might just think about replacing the operator (don't go with "Wayne Dalton")
Nov 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Cant get my RM-2 remote to work my olympus e500
The remote may be on a different channel than the camera.
Note: In cases of frequency interference or when you want to match the control frequency with the camera, aim the remote at the Remote Control window on the camera, and press the CH button and the W or T button at the same time until the Self-Timer/Remote control signal blinks or the camera emits a beep sound.
Sep 05, 2008 | Olympus Cameras
Olympus RM-1 Remote Control Logo
1,149 people viewed this question
Top Olympus Televison & Video Experts
ray gallant
Bill Boyd
Are you an Olympus Televison and Video Expert? Answer questions, earn points and help others
