I put a data or music disc in driver but system does recognize that there is a disc in the hard drive. Even after I right click start and explore the D drive is not there.
can the drive be downloaded or reinstalled with out having to re install XP operating system...
Try this. Click the Start button, click Run, type regedit in the Open box, and then click OK. click the + sign next to HKEY_LOCAL_MACHINE click the + sign next to SYSTEM click the + sign next to CurrentControlSet click the + sign next to Control click the + sign next to Class Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318} Delete upper or lower filters. if you see them both delete them both.
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free
CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and
DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image
Click start control panel administrive tools computer
management device manager scroll to cd/dvd rom drives right click properties
then properties again then tick enable cd
digital cd audio for this cd rom device or scroll to dvd regions select
the no _ for your specific area
If this does not fix the
problem you might try
Click start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
I have the same problem, the cd drive does not read any type of cd's (audio or data). the drawer does open and close, but even in my computer the d: drive does not exist, i have checked in the device manager and that is no help either because the only cd drive that appears may also be in the my computer file but, this drive only acts like a virtual drive as there is no response to the eject command when you right click on the icon. But it is not a virtual drive so i have no answers.
