Question about Car Audio & Video
Amp is going out.
I have a Lanzar 1600W OptiDrive 50C amp that is pushing 3 12" L5 solarbarics. it hits hard when working but it has started to drop out when turned up and now has even started quiting all together. most of the time the light stays on and green but sometimes the light goes red? whats the fix? is it the amp, speakers, or wiring?
The amp has thermal protection and will shut off if overheated.
It will flash the red light if the speaker leads are touching or shorted to ground.
It will flash if the impendence is to low or the voltage drops below 9 volts.
First do you have at least 10 ga speaker wire and 2 ga power wire with an 120 amp fuse?
You might need to upgrade your battery-alternator and add a cap
Posted on Jan 04, 2010
    Problem Solver:
  • 9 Answers
Have you tried replacing all of your fuses? If that does'nt work check your ground........ I would check all your connections also could be a connection shorting out causing your red light to come on.
Posted on May 15, 2009
Hi! I just inherited a Lanzar OptiDrive 1400D amp. Can anyone direct me to the Lanzar authorized or service centre in Singapore as I intend to send in for a general servicing. Thank you!
It appears that no identified service center exists in Singapore. You might want to try contacting Lanzar customer support directly for assistance: http://www.lanzar.com/ContactUs.aspx
Apr 17, 2015 | General Cell Phones
Is a boss ce2800 amp a good amp it says its 2800 watt class d mono block
It's over rated on it's specs and they run real hot when working hard. Make sure to located in an area with good air flow and away from material that may melt.
Nov 15, 2013 | Car Audio & Video
I just bought a old school lanzar opti 50c amp but i need to know what is the postive and negtive for the speaker output and what one is for bridgeing?and what is the spec? what is the lowest ohm i can go
the 50 C was used as a cheater amp back in the 90. You will be shocked by what this thing is capable of doing you can run an entire system subs mids and highs off of this 50 C. About 1300 watts
Jun 19, 2011 | Lanzar OPTI 50c Car Audio Amplifier
My Lanzar Optidrive plus has a green light and a red light. I assume this is a sign of safe mode. normally it is just green. How can i get it back to normal and in working order. I already tested other...
your output of the amplifier have been distorted. I suggest you take this to a reputable service technician that has experience with lanzar OptiDrive old school Rockford Fosgate or Orion. These technicians are hard to come by nowadays but they definitely are worth the money that they charge. I happen to be one of those such technicians.
Nov 15, 2010 | Lanzar OPTI 50c Car Audio Amplifier
How to wire 2 opti1533d by lanzar with the optidrive 2000d amp? how do i wire them if i put 1 amp on each sub
your speakers are 1 ohm per voice coil, dual oice coil. your amp is no lower than 2 ohms stable mono.
the proper way to wire this so that you do not burn out the amp is to run the 2 vioce coils in series. run the positive lead from the amp into the positive lead of one of the voice coils, then run a jumper wire from the same voice coil's negative lead to the same speaker's 2nd voice coil's positive input. then run from the 2nd voice coil's negative back to the amplifier's negative speaker lead.
you will be running for each speaker/amplifier set: amp + to terminal set 1 +, terminal set 1 - to terminal set 2 +, then terminal set 2 - to amp -
Oct 06, 2009 | Car Audio & Video
Lanzar Opti 50C
when there are burnt traces on board if its only a few you can bypass them with jumpers then all circuitry has to be checked and tested befor you go any further,can go into more detail just drop me a line randall 574-220-0162
Nov 30, 2006 | Lanzar OPTI 50c Car Audio Amplifier
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
