Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Software upgrade?
It works fine on XP, I am using it with XP SP3 currently. You should download the current driver from Minolta. Install the software before hooking up the scanner. I prefer to remove any existing drivers and re-boot before installing new drivers.
SOURCE: computer does not recognize my scanner
The current software is 1.0.3. It does work with this scanner and XP.
You should install the drivers after removing the existing driver and software. Do not hook up the scanner until the drivers have been installed.
It might not show up under the Cameras and Scanners section in Control Panel but it will still work.
When you open Elements make sure your scanner is on with the door closed. Go down to where you import and look for the scanner to be listed. It will take a minute or two to go through its calibration routine and then you should be able to scan with it.
SOURCE: I need a new set of holders, FH-U1 and SH-U1
Sillybit -- I have a SH-U1 slide holder. I'm looking for a FH-U1 film holder. Wanna swap?
