Question about Toshiba 36A40 36" TV
Black rectangle shape on my tv
There is a black rectangle shape on my tube...how do I rectify this problem
    President:
  • 788 Answers
Most of the time this is caused by the television being in "Closed Caption Text" mode. You can verify this by changing chanels and the box should go away for a bit.
All you have to do is turn off Closed Captioning in the menu or by using the CC button on the remote.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
Posted on May 10, 2009
Where is the engine air filter
It is in a big black rectangle shape box on the side of the engine compartment. There will be a black plastic tube shape going to it from the intake of your engine, There will be some snap type hold downs on it, pop those off, remove the top and take filter out. Take care.
Nov 14, 2010 | 2005 Lexus GX470
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
Big black rectangle in the middle of the TV
sounds like an advanced closed caption service is on. go to menu then audio then closed caption and turn off closed caption.
Jun 23, 2009 | iLO 3200 32 in. LCD Television
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Toshiba 35A44 35" TV
this is the closed caption set to text 1 2 3 or 4 go into the settings and either turn cc on to cc1 or turn it off
Aug 08, 2008 | Toshiba 35A44 35" TV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Black rectangle blocking view
SOUNDS LIKE U HAVE THE CLOSED CAPTIONING ON, CHECK IN YOUR MENU AND TURN OFF
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Toshiba 36A40 36" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
