Question about Sony Playstation 3 (PS3) Console
Hard drive problem
How do i restart the hard drive?
Re: hard drive problem
You have to go to system settings back up your stuff on memory stick(If you want to keep it). Then you go to format utility then chose quick format.
Posted on Mar 11, 2008
0 characters
3 Points
My ps3 slim has an error report saying that the hard disk has been corrupted. it tells me to restart and the hard disk will reformat. I have restarted 5 times now and it keeps giving me the same error. How...
Just as a guess, it sounds like the hard drive might be dead. If you have another 2.5" SATA hard drive, you could try it in your PS3. To swap out the hard drive, look at the bottom of the console, and right next to the warranty label, you'll see a little door that you can pull open with your fingernail. Open it, and you'll see a little blue screw. Just unscrew that, and put the screw somewhere for safe keeping. With the screw removed, you can now pull the hard drive out from the bottom right of the front of the console, unscrew it from its chassis, and place the new one in and put everything back together. Once you turn on your PS3, you should get the error again, but let it restart, and everything should be fine.
May 11, 2011 | Sony Playstation 3 (PS3) Console
My playstation turns on and the green light comes on but it turns to flashing red in about three seconds. It never comes up on the screen
It could be a failing hard drive...Try to remove the hard drive from the system and restart it without the hard drive if you can at least get to the main menu then it is your hard drive that is causing the problem.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
My hard drive has turned into a memery unit with my transfer cable and i dont know how to change it back to a hard drive any ideas please
Did you unplug the transfer cable and plug back in the hard drive to the Xbox? might have to restart Xbox afterwards. anyways the hard drive is a memory unit.
Jan 20, 2011 | Microsoft Xbox 360 Hard Drive (120GB)
I connect hard drive but my xbox cant find it
Hello, and thanks for using FixYa.
the drive is plug in play, disconnect the drive, then turn on the console. Plug in the drive, the console should restart and it should be found. if it restarts but the drive is not found then the drive is either faulty or it has been editted somehow and no longer contains what is required for it to work on xbox.
You may use USB memory stick as a hard drive / memory device, just update to the latest version of software and you can use any usb stick up to 16GB with the console. this will be cheaper than buying a new drive.
Please let me know if you require further assistance or if you have any questions.
Oct 22, 2010 | Microsoft Xbox 360 Hard Drive (20GB)
Turns on but nothing on the home screens show up stuck in load mode
Remove the hard drive and turn it on with it out. Put the Hard drive back in and restart it. If this does not help it could be bigger problems. I would try to get a different Hard Drive to try. Some Laptop hard drives will work as long as they are SATA conector type. Good Luck.
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
Some games such as infamous and assassins creed (1) freeze
ive had they same problem with my ps3 and i decided to restart the whole hard drive, not reformat the system, beware restarting the whole hard drive will erase all memory in the system.
hope this helps
Jun 06, 2009 | Sony Playstation 3 (PS3) Console
Xbox 3 red lights problem help please
3 red lights normally means there is a general hardware failure.
Are the lights flashing?
Turn off the xbox and...
Try unplugging everything from your xbox, plug it back in and turn it on.
if that doesnt work, when your xbox is turned off, take the hard drive out and restart your xbox. If it works with the hard drive, try restarting it again after putting the hard drive back in.
Apr 10, 2008 | Microsoft Xbox 360 Console
E68 problem
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
If this doesnt solve the problem, then contact xbox customer support.
Mar 24, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
60 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
