Question about Garden
Pressure Washer problem
I have a briggs & Stratton 3.75hp pressure washer. It was running rough, plug constantly fouled and it stalled out. I cleaned plug and put back in but kept happening. I put carburator cleaner into carburator and now it stalled and won't start.. Suggestions....
    Genius:
  • 1,198 Answers
If it has the same good compression it did when new, replacing the carb will probably fix your problems. Be real sure about the compression, an engine with low compression and a funky carb might just as well get replaced.
Posted on May 10, 2009
What is spark plug gap on unidentified pressure washer?
Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonLearn how & where to find the right spark plug and a gap chart to guide you through ...are commonly used for walk behind lawn mowers and pressure washers.
Spark Plug Gap - Troy-Bilt
Nov 24, 2015 | Garden
Constant pressure
Some of these machines require you to hold the spray handle trigger in the open position while starting the motor, once it is running let the trigger go and it should run on bypass
Apr 11, 2014 | Craftsman 2500 PSI Briggs & Stratton...
Engine wont stay running
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
May 23, 2010 | Briggs & Stratton Power Products 1539...
Craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Jan 29, 2010 | Briggs & Stratton Pressure Washer...
I have a briggs & stratton pressure washer that every time I engage the spray hose my pressure washer stops. Why???? I have left it running for a couple mins. before engaging, doesn't seem to help
PROBABLY the valve that admits the water to the pump is sticking. USUALLY bad O-Rings. If the valve sticks closed, the pressure won't build up. If it sticks open, the washer will stall. Most other problems are engine problems due to bad gas, carbureator, etc.
Oct 09, 2009 | Briggs & Stratton Garden
On a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Garden Logo
287 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
