Question about Dishwashers
DIshwasher will not drain.
My dishwasher will not drain. I have removed and inspected the drain hose. It is free of clogs. I have removed the dishwasher onto my back deck, but nothing will drain from it. What should I check next?
  • rogerdeloach May 13, 2009
    Hey smartr10U,
    Thanks for the input, it is deeply appreciated! However, I had a clogged Check Valve. My 22 year old son spend the past five days at our house, while my wife and I were out of town. Apparently he developed the habit of eating sunflower seeds, spitting the hulls into his mothers glassware and then loading them in the dishwasher; while we were gone!
    After working the dishwasher over, I was too pooped to work him over ... but his day is coming! (Only Kidding, why kill off your Free Lawn Mowing Service).
    Thanks Again, Roger
    Thanks for your seed shell suggestion! I may have to give that one a try! :) My Wife is Thrilled that I got it working, and that is priceless!!! Thanks Again, Roger
  • 1,305 Answers
Check the pump and the area where the pump picks up water.
It could be that the pump gave out, or it's inlet may be plugged usually on the dishwasher side of the drain hose.... good luck let me know what you find.
Posted on May 10, 2009
  • KEN LaPOINT
    KEN LaPOINT May 13, 2009
    Take the seed shells you got out of the machine and toss em in his bed... just kidding... my fatherin law always said, "KIDS! you don't know whether to kiss em or kill em!"
    Glad you got it working!
When cycle is finished there is still water in the bottom of the dishwasher
Hi and welcome to FixYa I am Kelly.
Water in the bottom of the unit is a sign of drain problems that are usually external to the dishwasher. You probably have noticed cloudy or spotted dishes post cycle lately also. Since I suspect a drain problem here is what you should do:
  • Start at the sink connection and remove the hose. Then clean out the port at the sink or garbage disposal connection. Reconnect the hose. (Clogged garbage disposal ports are the 2nd highest reason for dishwasher drainage problems.)
  • Next if you have an Air-Gap installed pull off the upper/outer cover and NOTE the position of the internal cap and nut. The cap with the inner inverted U will only install correctly in one position. Remove the nut and lift off the inner inverted U cap. (This is were most clogs are found.) Clean out any debris found. Use a flash light and inspect the lower outlet hose port for obstructions. Remove the lower outlet hose to the sink / garbage disposal connection if necessary to clean the outlet port.
  • Lastly... If after doing the above and you still have water in the dishwasher post drain cycle then TURN OFF POWER to the dishwasher and remove the lower kick panel. The remove the drain hose from the pump and inspect the port for obstructions. Clean as necessary. Re-install the removed hoses. (Check all) Install the lower kick panel.
TURN ON POWER and test the drain cycle after filling with water. This should make it work properly again unless there is a problem with the pump impeller blades or something inside the sump housing blocking the drain port. If you have done all of the above and you still have the same water in the sump post drain cycle problem... Just respond here and I will explain what to do next.
Thanks for choosing FixYa,
Kelly
Feb 27, 2011 | Bosch 24 in. SGS43C12 Classixx...
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
WASHING MACHINE SHOWING ERRORMESSAGE 5E
rw
Hello, and sorry to read about you 5E code issue.
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
If your hose shows no kink's you may have a clogged pump.
I have tried to help you. PLEASE rate/vote the response. we take the time to respond to you. take the time to rate. Thanks and good luck on your problem.
Dec 24, 2010 | Samsung WF306BHW High Efficiency Front...
I have 5E showing on my dishwasher. What is does this error mean?
ost common error codes that are caused by installation errors are:
  • 5E. If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
  • Info provided by Articlead.com
Dec 09, 2010 | Samsung DMR57LF Builtin Dishwasher
Beko dishwasher not draining
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Nov 20, 2010 | Beko 24 in. D3421F Free-standing...
Water is not draining
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 08, 2009 | GE Dishwashers
My hotpoint HDA3400G is not draining and i am unsure if the problem is the dishwasher or a clog in my plumbing.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 25, 2009 | Hotpoint 24 in. HDA3400G Built-in...
MY GE Triton GSD5120D00BB won't drain. Please help.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 17, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher isn't draining completely
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Apr 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher wont drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 09, 2009 | Whirlpool DU930PWS Built-in Dishwasher
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
