Hi
Some leaking around-under-from the door on dishwashers can be traced back to a split in the spray arm. If the lower spray arm develops a split in it, the spray arm can turn too fast, and shoot water directly at things that it is not suppose to spray water at....sprays water at the door vents or edges and can create water leaks.
You should remove power and check the spring and plastic tab under the timer, often the plastic tab breaks and the soap door will not stay closed. You can try to install a small screw where the tab use to be to re-hook the spring. If that is ok, you will have to check the rest of the dispenser arms, door cover and handle. The spring on the round dispenser should look like this. #1 hooks on a groove cut into the dispenser arm, #2 hooks onto a tab built onto the inner door panel.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
