Question about GE GSH25JFR Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
The water dispenser is not working but the ice maker is working fine. What could be the problem?
  • 12 more comments
  • lucydi1 Nov 08, 2007
    my ice dispenser works fine but my water is not coming out...model 22, 20, or 25....i need help
  • TEILON Nov 13, 2007
  • Anonymous Dec 09, 2007
    no water
  • aogfixer Dec 18, 2007
    water and ice dispensers not working no power to the unit. Light in dispenser is also out.
  • Charles Burke Dec 21, 2007
    Water dispenser not working but ice cube maker working fine on my GE Side by Side Refrigerator Model Number GSA 25 VGPQA WW bought 4/14/04. I can make the water dispenser work by removing the water filter and filling it with warm water and by rubbing the underside of the ice cube container with a wet, warm cloth for several minutes and by keeping the doors open until the temperature rises. This fix lasts for one to four days. Can you help?
  • Anonymous Dec 28, 2007
    i have the same issue... any fix?
  • DeJon Mar 08, 2008
    I have the same issue - everything on the front panel (ice cubes and crushed ice) works but not the water - it will work for awhile - then it stops and I am not sure what to do - I have replaced the filter and that does not solve the issue...any suggestions?
  • Anonymous Mar 13, 2014
    ge gss23wgta bb ice maker works but doesnt fill with water and vavles work
    runs water when filling ice maker
  • Anonymous Mar 17, 2014
    The ice maker works, but will not dispense through the door. The water works fine.
    GE PSS26MSTDSS not dispensing ice cubes. have to pull out the tray to get them manually
  • Anonymous Mar 25, 2014
    Ice maker is not producing ice. I replaced with a new ice maker and still no ice production. I have good water pressure at the dispenser.
  • Anonymous Mar 27, 2014
    water dispenser not working ice maker is operational
  • Anonymous Mar 29, 2014
    it worked fine until the line froze up
  • 18 Answers
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
Mine did same thing. What is happening is the Water Line in the freezer door is freezing.
SOLUTION. Leave the freezer door open and turn off the freezer for a night. Be sure to dump out all of your ice cubes too.
In the morning it will work like new. To prevent it from happening again, open the FRIDGE door and use the electronic controls to raise the temperature of the freezer. You had it too cold before...thats why your water line froze in the first place.
Posted on May 02, 2008
    Problem Solver:
  • 14 Answers
This is a common problem for GE refrigerators. Fortunately there is a simple, inexpensive and permanent fix. GE released a water line heater that is easily installed. More details on the and solution here.
Posted on Dec 13, 2010
    New Friend:
Borrow your girlfriend or wife's blowdryer warm the inside of the door where the water runs out of. I had to do it for 3 to 5 minutes on warm to high heat. Keep the settings for your freezer on no higher than 4. 3 works good too.
Posted on Mar 23, 2014
    New Friend:
I run a dishcloth under the hot tap till it's very hot, then I squeeze most of the water out, open the freezer door, press this very hot cloth against the inside door (opposite and above where the dispenser is) for a couple of minutes, do this a couple more times, and after another couple of minutes the dispenser works again. Have done this several times and presto, no problem.
Posted on Jan 28, 2013
    New Friend:
Someone had suggested using a 10 inch piece of weed eater wire in the water line with about an inch hanging out of the front of the fridge. And if it refreezes just pull it to break the ice plug in the line. This absolutely works but I could not get the line to defrost in the first place so to get the wire in the water dispenser. So...I propped a spot light on a bar stool and pointed it at the water dispenser tray (about two feet from the fridge) for about 5 minutes. The door gets very warm. Then I opened the freezer door and pointed it at the back of the water dispenser where the tube is ran inside the door for about 5 min. It melted the plug of ice and worked like a charm!
Posted on Dec 25, 2012
  • chambersshan
    chambersshan Dec 25, 2012
My GE side by side water dispenser tends to freeze up during the slightest change to cold weather. Initially we would have to open the freezer door for about an hour removing frozen food from the door and blocking the freezer compartment with a large automobile sun shade and eventually the line would defrost and water dispenser would resume working til it would freeze again. Instead of buying and installing the heater device sold by GE, I cut about a 12 inch piece of weed eater trimmer line, tied a knot in the end and inserted that into the dispenser tube. Then when the line freezes again you grab the knot for grip and pull the trimmer line out and water will flow; reinsert the trimmer line before the tube freezes again and repeat the process as required when tube freezes.
Posted on Nov 28, 2010
  • phild12 Feb 22, 2011
    I had this problem for the last few years -yes turning off the freezer with the door open for a few hours worked but is a royal pain in the neck. Using a hairdryer for 15 minutes does too, when it keeps freezing up agin every day. I also had a repairman install the GE kit to keep it from freezing - it worked for awhile, but then stopped working, and the water line again froze up. Looking at solutions around the Internet, the one that made the most sense suggested that there was insufficient insulation in the freezer door directly behind the water dispenser; i also noticed freezing air blowing directly there when the freezer was running. So I simply stuffed a cloth towel on the inside of the door where the ice comes through, and hanging down in front of the flat part behind the dispenser - and it did not freeze for several days. i then got a flat piece of insulating styrofoam, about 10inx11in, attached it by velcro to that flat part on the inside of the door, and have not had a problem since.
  • 473 Answers
What is the complete model # from the sticker on the inside of the fridge section?
Posted on Oct 11, 2007
This is the model number from the registering card
Posted on Oct 15, 2007
    Problem Solver:
  • 7 Answers
See my posting " i've tried every thing shot of " for this model
5 Suggested Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I have the same problem, although mine is intermittent. Apparently it's a problem with the line freezing. For an excellent discussion of the issue, see http://www.askmehelpdesk.com/advice/t-14182.html
Posted on Jan 05, 2008
  • 1073 Answers
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
Templarius
  • 86 Answers
Clean the water disposer
Posted on May 26, 2008
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Dec 20, 2007 | Refrigerators
GE GSH25JFR Side by Side Refrigerator Logo
9,851 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
