Question about Samsung DVD-V4600 DVD Player/VCR
I've opened our Samsung DVD v4600, just to clean it a little. It now does not play DVDs. It gets stuck on "LOAD". A small plastic tab at the back center of the case broke of when I removed t
I've opened our Samsung DVD v4600, just to clean it a little. It now does not play DVDs. It gets stuck on "LOAD". A small plastic tab at the back center of the case broke of when I removed the top. Could this be causing it to malfunction?
  • brentanna May 10, 2009
    Hmmm, thank you.... I will try to move the laser tray. And, I did remove the tab staright away, so that isn't the problem.
    OK, I cleaned the eye and moved the laser thingy up the sliding bars toward the back of the unit. But, no luck. It's odd because it had been working all right. Thanks for your tips though!
  • 11,896 Answers
I don't believe the tab has anything to do with it. You will have to manually push the laser tray all the way up to starting position and try again. It is actaully a very common problem with many players. The timing may have jumped.
Posted on May 10, 2009
  • Nate Stansfield
    Nate Stansfield May 10, 2009
    You should try moving the tray. You can also clean laser eye with cotton swab and rubbing alcohol. I wouldn't try anything else on it or it may scratch the lens and won't read anything.
    If none of these solutions help. Than I suggest replacing the unit. It would be around $120 for repair.
  • Nate Stansfield
    You are welcome. If that didn't fix it, it will have to be taken in to tech or just be replaced which will cost almost the same.
    Like I said, it is very common problem with many disc players. And I work on them often, have yet to find much luck with the doors. Usually have to test all capacitors, and then completely remove the door, gears, and everything and reassemble.
  • 163 Answers
If the tab or pieces of it fell into the mechanism. Also look to see if the tab held something in place. Hope this hepls.
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
Samsung DVD-V8600.....DVD won't load
open cover and clean the laser with alcohol and try again
Mar 13, 2010 | Samsung DVD-V8600 DVD Player/VCR
I have a Samsung 1080P 7 DVD player and Samsung LN-T4071F television. I have them connected via an HDMI cable. Nearly all, if not all DVD movies I play get to a certain point and the picture starts...
If you have changed the DVDs and the problem is still there, then the problem can only be the DVD player.
The symptoms you describe cannot be caused by the TV or the connection.
May 19, 2008 | Samsung Televison & Video
Samsung DVD/VCR combo (DVD v4600) makes loud sound when playing dvds
probably cheaper to replace than repair sounds like theDVD drive has worn parts or is about to go out.
Jan 13, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung dvd-v4600
Wish I could. I have the 4600 combo and the VCR works fine. The DVD stopped working many months ago and just yesterday started working fine again. Worked fine for two days and then stopped, picture froze, and all I got out of it, is the picture is loading. Wont give me back my DVD nohow, so have opened the case and stole it back. Tray will not open at all. Trying some repairs, will holler if succesful
Dec 20, 2007 | Samsung DVD-V1000 DVD Player/VCR
Region code fro a samsung dvd v4600
there are web site's on google for this, type region codes for make of dvd player and hacks .
riz.
Nov 12, 2007 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Samsung dvd-v4600
sounds like you need to clean the laser lens. Try using a disc cleaner first and if that dosent work then take aprt and find the laser lens, take a clean q-tip and put a little alcohol and swab the lens very carefully Good luck
May 09, 2006 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
304 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
