Question about Jensen's VM9312 Car DVD Player
How to set auto vol. control? every time i start car or turn to acc. on ignition it will go back to vol. level 30. what do i do to stop this?
  • Anonymous May 22, 2009
    how to set auto vol.everytime i start
Turn the volume to where u want it to start at and then press in on the vol button
Posted on May 27, 2009
The oven turns its self ON every 20 to 45 mins. The electric ignition glows and the gas comes on and burns for about 30 to 60 secs then turns off. The oven control knob is turned OFF. There are no aut
Seems to me you have a defective control panel board.. Ovens should never do this. Time for the Serviceman right away, this could be dangerous if you are not home.
Nov 24, 2014 | GE Kitchen Ranges
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Reset passlock code
Is your Impala a 2000, 2001, or 2002? This seems to be a common problem in those model years...much like its predecessor the GM VATS (Vehicle Anti-Theft System). While the VATS had a permanent (albeit unapproved) solution, no suck workaround appears to be available for the Passlock system. Some websites offer a correction "module" that looks to be a hit-or-miss solution. I did find the following procedure on a forum, and it seems to be reliable. Here goes:
If your car has been sitting while you were at work or home or in the store, and you are coming out to leave, follow steps 1-6.
If you just had the SECURITY SYSTEM lock you out of the ignition system, you will have to wait the 10 minutes for it to reset and allow the ignition control module to interact with the system. Once the 10 minutes have passed from the ACTIVE SECURITY STATUS, follow steps 1-6. Do not try to shortcut this as it wont work.
If it is raining, you can close your door, just not all the way. Close it all the way and open the door latch without pushing the door open. This will keep you dry.
+++++STEPS+++++ 1.) OPEN YOUR DRIVERS DOOR AND SIT DOWN. 2.) PLACE KEY IN IGNITION, WAIT FOR CHIME. (3 seconds is what I usually wait) 3.) TURN IGNITION 1 CLICK RIGHT (TO THE ACC POSITION) AND STOP! Do not continue to ON and START yet. WAIT ATLEAST 5 SECONDS 4.) AFTER 5 seconds has passed, TURN KEY TO ON and STOP, DO NOT CONTINUE TO START YET! 5.) WAIT AND WATCH. With your drivers door open, here is what you will see and hear = Your notification will signal DOOR ADJAR, then the BATTERY light, then the SECURITY light, during which you will hear the chime sound as if you just started the car. 6.) AFTER YOU SEE THE SECURITY light switch back to DOOR ADJAR or Battery, and after the CHIME has stopped, you can turn the key to start and voila!
It has worked every time for me and 5 of my friends. This whole process takes about 20-30 seconds, but it sure as hell beats 30 minutes, as GM refuses to compensate my time lost to their vehicle\'s design flaws.
RECAP: 1.) Open driver door, sit down 2.) Insert key in ignition, wait for chime 3.) Once chime starts wait 3 seconds 4.) Turn key to ACC position WAIT atleast 5 seconds 5.) After 5 seconds turn key to the ON postion and wait for the security light to switch back to Battery or DOOR adjar, and the chime to stop (Do not try to START if the chime is still sounding) 6.) Once chime stops and Security light has passed, You may now complete the turn to START and it will start.
Note: This is not a permanent workaround, but it will buy you some time, I can almost guarantee it will work for most if not all people, almost all the time.
Oct 11, 2013 | Chevrolet Impala Cars & Trucks
How can i get the words to which fuse operates what part of the car in an 06 charger???
Hi, All the Info You Need Is Detailed Below:
Front Power Distribution Center Fuses
# Amp Description
1 20 Yellow Left High Beam Headlight
2 20 Yellow Right High Beam Headlight
3 15 Dk. Blue Adjustable Pedal
4 20 Yellow Horn
5 25 Clear Headlamp Washer If Equipped
6 15 Dk. Blue Front Control Module (FCM)
7 20 Yellow Fog Lamp
8 15 Dk. Blue Park Lamp
9 15 Dk. Blue Non ABS Brakes
10 5 Orange Starter
11 20 Yellow Auto Shutdown/Powertrain Control Module (PCM)
12
13
14 25 Clear Powertrain Control Module
15 20 Yellow Injectors, Ignition Coils
16 15 Dk. Blue Powertrain Control Module
17 30 Pink Antilock Brake System (ABS) Valves
18 30 Pink Windshield Wiper/Washer
19 50 Red Radiator Fan
20 20 Lt. Blue Starter
21 50 Red ABS Pump Motor
22 40 Green Radiator Fan High/Low
23 50 Red High Intensity Lighting
24
25 30 Pink Lighting Left High Beam/Right Low Beam
26 20 Lt. BlueTransmission
27 30 Pink Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center Fuses
1 60 Clear Ignition Off Draw
2 40 Green Battery
4 40 Green Battery
5 30 Pink Heated Seat/Steering Column
6 20 Yellow Fuel Pump
7
8 15 Dk. Blue Ignition Start/Run - Start
9 20 Yellow Console Power Outlet
10 10 Red Rear Fog Lamp If Equipped
11 25 C/BRKR Memory Module/Door Locks
12 25 C/BRKR Passenger Power Seat
13 30 C/BRKR Door Module Run/Acc/Delay
14 10 Red Sentry Key/Remote Keyless Entry/Cluster
15 20 Yellow Brake Light (5.7L)
16 20 Yellow Power Outlet Trunk - if equipped
17
18 20 Yellow Selectable Power Outlet
19 10 Red Stop Lamp
20 20 Yellow Rear Wiper If Equipped
21
22
23
24
25
26
27 10 Red Airbag/Occupant Classification Module
28 10 Red Curtain Airbag - if equipped
29 5 Orange Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
30 10 Red Steering Column Module/Power Mirrors - if equipped
31
32
33
34
35 5 Orange Power Antenna/Garage Door Opener/Ignition Delay
36 20 Yellow Radio/Navigation
37 15 Dk. Blue Transmission
38 5 Orange Analog Clock/Garage Door Opener
39 10 Red Heated Mirror
40 5 Orange Power Mirror
41 10 Red Climate Control Module/Headlamp Leveling if equipped/Rear Park Assist if equipped/Tire Pressure Monitoring if equipped
42 30 Pink Automatic Temperature Control (ATC) Blower Motor
43 30 Pink Rear Defroster
44 20 Lt. Blue Audio Amplifier
Sep 13, 2012 | Cars & Trucks
I have a philips remote control and I need the code to control a pioneer DVD player
Though all remotes are differnet just try this it can be kind of standard. But not all remotes are always compatible
1. On the remote control, press DVD once and Turn DVD player off
2. Press and hold SET until the red light blinks twice, then release SET.
3. Aim the remote control at the TV and press SCAN. The red light will blink twice.
4. Continue aiming the remote control and click on and off at the DVD Player (which may take up to 5 minutes) until it turns off. Immediately press any key except VOL-, SCAN, or SET. If SCAN is pressed again after any key stops Auto Scan, the remote will continue Auto Scan of the next ID from where it stopped. If you have passed by the code that turns off the TV, press VOL- one or more times until the TV turns on again.
5. To lock in the code and exit Auto Scan, press and release SET the red light will blink twice.
1. Or if you have a code. Press Set
2. Wait for blinks
3. Put in code.
4. Test it and if it works click set if not try next one.
Jul 17, 2011 | Philips Televison & Video
My c.d. player in my car resets all the settings every time i turn the car off
By the sounds of this one you have no permanent live feed to the unit. When you switch the ignition off you cut the power to the unit which should have a constant live feed to retain memory.
This is normally fed via the ACC position. If you do not have the ACC position available, then be sure to set the Auto Off function. The unit will shut off completely and automatically in the set time after the unit is turned off, which prevents battery drain. I f you do not set the Auto Off function, press and hold (SOURCE/OFF) until the display disappears each time you tum the ignition off.
(Rear of unit multi-plug) RED is 12V + to ACC Cable YELLOW is 12V + to constant live Cable BLACK is - Ground Cable
Good Luck with it.
Mar 28, 2011 | Sony CDXGT650UI
How to turn of oil light and tire pressure light? without bringing it to the auto repair shop the car is a 2001 chevy monte carlo LS
it is done through the factory radio.
dont have factory radio?
1. turn the ignition key from Acc to on then back to Acc twice. 2. turn your head light switch on and off three times. This should reset the warning light. The change oil light can be reset by pressing on the gas peddle three times in place of the headlight switch.
Jul 22, 2010 | 2001 Chevrolet Monte Carlo
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
Set the combination lock on the driver door of 1999 Ford Explorer
check your car manuel and it should tell you to solve both
Jun 09, 2009 | 1999 Ford Explorer
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
Jensen's VM9312 Car DVD Player Logo
188 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Jose Velazquez
Jose Velazquez
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
