Question about Kenmore Elite 45986 Front Load Washer
Waher spins like it is out of balance. - Kenmore Elite 45986 Front Load Washer
  • Anonymous May 12, 2009
    Our new washer also spins as if it is out of balance. We have leveled the washer, but it doesn't seem to help much.
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
When agitating, washer moves side to side three to four inches each way. It hits against metal brackets under motor. Thank-you.
Depending on you model you may have a propblem with you inne tub not properly attached to the transmission shaft.
Also check all the spring that help keep the waher tub in place and balanced.
Mar 08, 2010 | Washing Machines
Kenmore #110.26954690 won't spin in spin cycle
If it doesn't pump out water either, yes, first, I would suspect a broken belt (or motor coupling if direct drive).
Unlikely that the center cone is jammed.
Charlie
Aug 23, 2009 | Kenmore 22422 Top Load Washer
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Spin problem
you probably have a partial clog in your pump not allowing all the water to drain out the first time.id check the pump first
Jan 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum speed slow on final spin
what waher is this and what speed is it
Dec 05, 2008 | Kenmore 46462 Front Load Washer
Check the lid switch first.. if that's ok..then you may have a broken drive belt or the load is too great for the waher to move it.. Do you hear the motor spinning but the drum isn't rotating? Or is it just not doing anything during the spin cycle? Hope that helps..
Sep 01, 2008 | Washing Machines
Lg washer wm227wh
  May be a broken off balance sensor.  This would go along with everything else that was damaged.  It senses off balanced load and slows machine.
Oct 23, 2007 | Washing Machines
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
79 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
