Question about Garden
Honda engine oil leak pressure washer - Garden
5 Suggested Answers
  • 3600 Answers
SOURCE: pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Posted on Jun 22, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
  • 57 Answers
SOURCE: There are 2 different places to add oil to my 3500
you can use sae 30 in the motor and hydraulic oil or gear oil in the pump.
just note that there may be two oil filler holes on the motor.
Posted on Jan 10, 2011
Testimonial: "Thank you very much for verifying the oil for me."
SOURCE: karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Posted on Jun 26, 2012
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
Hi honda activa 2008 model engine oil leaking.
Pressure wash the engine then try to locate the source of the leak first. Seals don't usually start suddenly unless you overfill the motor. If you have just had it serviced look for leaking drain plug where they left off the crush washer, oil filter not tight, simple stuff first.
May 11, 2015 | Honda Motorcycles
WHAT OIL SHOULD I USE FOR THE HONDA BM80913A PRESSURE WASHER . I HAVE OIL FOR 2 CYCLE ENGINES BUT I AM NOT SURE IF I CAN USE IT. I do not have the service manual available
If you are asking about the oil for the gasoline engine then you can use a 30 weight engine oil like you would use in a car engine. Pressure washer pumps use a special non-detergent oil which is not the same as the engine uses.
Jul 16, 2011 | Honda Black Max 2600 PSI Pressure Washer
What type of oil can i use
The engine and the pump can use the same oil. SAE 30 non detergent oil. No need to pay more for speciality oil. Check oil often and look for any unusual signs such as milky or foamy oil in pump which would indicate water leaking past seals. Good luck.
Sep 04, 2010 | Honda Black Max 3000 Psi Pressure Washer
Oil leak appears to be from pump, not engine, GC160. What oil and how much should be replaced. what might be source of leak
some pumps have a side glass and oil should be half of side glass and depends on manufacture oil is different if general pump you can use 30w non detergent
Aug 24, 2010 | Honda Pressure Washer PSI 3000
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Oil in my honda civic 1991 is dripping all over but only when the car is running any ideas?
your the only one that can answer where, check the oil filter and the oil light switch first.
Oct 02, 2009 | Honda Civic Cars & Trucks
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Honda 2500 pressure washer,
The oil in the front of the washer turned a cream color...like it has water in it. Any comments?
Apr 26, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
701 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
