Question about RCA RCR412C Remote Control
Program for my tv
Need to know what buttons to push to program remote for my tv
THANKS YOU SAVED US FROM OUR ROOMATE KILLING uS OVER DE PROGRAMING HER REMOTE CONTROL> WE LOVE yOU
Posted on May 02, 2008
Push the t.v. button on the remote then push and hold the on/off button and the t.v. button down at the same time until the on/off button comes back on and stays on, then you release them both. Then push the CH+ or channel up button on the remote and the on/off button alternatively until the t.v. goes off or comes on, each time you hit the CH+ button on the remote you are advancing the code for you t.v. forward in your remote, after your t.v. comes on or off then hit the stop button on the bottom of the remote and you have stored the code for your t.v. Hope this helps.
Posted on Oct 21, 2007
ThaNK U RoCk!!!
Posted on Apr 08, 2008
    Problem Solver:
  • 12 Answers
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Dec 15, 2007
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
Need program instructions
I need the model receiver you have to do this.
Jul 25, 2009 | DISH Network IR Remote Control
Can't program emerson tv control volume or to turn it off.used all codes.not working.all other controls work. Thanks,ladybrd
If this is a new Emerson flat panel lcd tv from Walmart, there is a chance that the remote just wont work. I've had problems with these Emerson's often with all dish network remotes. you can try doing a search on the remote itself though. Turn your tv on manually, then push the tv button on the remote and hold it until it flashes, then hit the tv power button on the remote, then push the up arrow button continuously (not to fast though) until the tv turns off and then push the # button (below the 9 button) and the remote should work. There are some new tvs' that these remotes just wont program. I hope yours works.
Jul 22, 2009 | DISH Network IR Remote Control
Buttons to push on universal remote to program channels
There are 4 methods to program your remote.
CLICK HERE for the user manual
Thanks for using FixYa - a FixYa rating is appreciated!!!
Jan 31, 2009 | RCA Universal Remote Control
Codes to program the RCA Universal remote control for a Magivox T.V.
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
Sep 13, 2008 | Televison & Video
Programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
Jul 21, 2008 | Zenith DBZN-311 Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Hold button down for unit you want to program. (TV,DVD,VCR) Then hold down on off button at same time. On/off button will turn off then come back on. When this happens push the play button. Wait 10 seconds and then push again. Repeat until unit turns off. Once unit turns off push rewind button one at a time until unit turns back on then push the stop button.
Sep 29, 2007 | RCA RCR311B Remote Control
RCA RCR412C Remote Control Logo
154 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
